Radio problems
Old Dec 3, 2007 | 8:12 PM
rldtahoe's Avatar
Default Radio problems
When I start the Tahoe, at times, the radio speakers will not work. The radio functions normal, but no sound comes out of the speakers. Has any one else had this problem?
Old Dec 3, 2007 | 9:05 PM
doo600's Avatar
Default RE: Radio problems
Need more info. What year vehicle and what stereo.
Old Dec 4, 2007 | 1:51 AM
engine2's Avatar
ORIGINAL: doo600
I second that, but you might start by checking all the wires and connections to see if anything is loose.
Old Dec 4, 2007 | 11:26 AM
ZX1100F1's Avatar
ORIGINAL: engine2
ORIGINAL: doo600
+1
If Bose system then start with the plugs under the center console going to the amplifier, a loose connecter here is commonly the problem.
Old Dec 4, 2007 | 11:48 AM
rldtahoe's Avatar
It's a 2003 and it has the factory bose stereo
Old Dec 4, 2007 | 2:18 PM
ZX1100F1's Avatar
Ok then see above.
Old Dec 4, 2007 | 8:22 PM
rldtahoe's Avatar
Thanks for the help!
Old Dec 12, 2007 | 9:57 AM
bk_gamm's Avatar
Hello, I am new here, but have done lots of reading. I have a 2004 Suburban Z71 and I am having the same problem as rldtahoe. Radio works fine, but no sound. The sound cuts in & out on allspeakers. I've pulled the head unit & swapped with another and still having the same problem. I've checked all the wires & plugs and there doesn't seem to be any loose connections. Is it possible the amp is toast?? Are these repairable? I'd hate to spend $300+ for a new amp. Has anyone else had failures with the Bose amp?? Any suggestions or ideas would be appreciated. One other question, does anyone have a wiring schematic for the stereo system, and more specifically the Bose amp??
TX in advance.
Old Dec 12, 2007 | 10:30 AM
ZX1100F1's Avatar
Welcome:
For the 2004 Tahoe:
1. Check for audio at the Rear Seat Audio controls through the head phones. If there is, then the radio is producing audio.
2. Check pin B11 (switched 12volts) for 12 volts. This is a pink wire on the large Gray connector at the AMP This is a radio output that tells the amp to turn on. It should show 12 volts, if it does not, and then radio B3 pin output is not operating properly. This could be caused if the radio is not programmed correctly or a circuit concern.
3. Check pin B1 (amp mute) for 0 volts to 5 volt, this a Gray/Black wire on the large Gray connector at the AMP, If the voltage is between 0 and 1 volt this tells the amp to un-mute and play. If it shows between 3 and 5 volts this tells the amp to mute and stop playing. This could be caused if the radio is not programmed correctly or a circuit concern.
4. If the above steps indicate that the system should be playing then check for power and grounds to the amplifier and if ok, replace the amplifier. The Black/White wire on the small connector at the AMP is Ground, the Orange wire is +12V.
Old Dec 12, 2007 | 11:32 AM
bk_gamm's Avatar
ZX, Thanks for the speedy reply and in-depth answer, I will check all those things. Before I start, I do know that I was NOT getting any audio thru the rear audio headsets. Any additional steps you can provide with that info??
TX again.
