rear door/hatch on 02 burb
Old Apr 6, 2014 | 3:28 PM
Desert Gringo's Avatar
Default rear door/hatch on 02 burb
How to open the rear hatch/door it lifts up...not the barn door type.
How to open it up from the inside? going to use it to sleep in and would like to be able to open that door from inside the vehicle instead of using the side doors. anyone know how to do this?
thanks
Old Apr 6, 2014 | 4:57 PM
I don't think there is a way...(without modification) I have wondered that myself for the same purpose... seems like it would be easy enough to add a momentary switch in the side pillar where its not likely to get bumped or activated....
if yours is mechanical , seems like you could install a generic door lock actuator, as they are fairly inexpensive...
Old Apr 8, 2014 | 6:54 PM
Thanks in2pro, I was hoping there was a pull cable I was not seeing, as I do have a mechanical latch. I think I will just make a pull cable. I guess I will be taking off the rear plastic lol
Old Apr 9, 2014 | 7:08 AM
I'd take a look at it and see if you can add an aftermarket lock actuator and a momentary button, but you will have to run power into the door somehow... do keep us posted and if you can take a few pictures of the project if you add the pull cable..
Old Apr 23, 2014 | 6:12 PM
I have not yet had the time to take off the rear plastics on the hatch yet, but maybe tomorrow yeah tomorrow. But I just found out that tomorrow never comes, damn my luck. When I do get to it I will post some pics of what I intend to do with this issue, as I really want to open the rear hatch or even the complete hatch door .
Old Apr 24, 2014 | 9:36 AM
BW56's Avatar
I'm on my 3rd suburban and wanted to do that to each of them, tomorrow. Like you tomorrow has yet to come. I always wondered why GM never put a way to open the back doors/hatch from the inside. Trunks have a safety release, why not our door/hatch? Hey GM, It's in your ball park now.
grs1956
May 2, 2021 10:24 AM
martin18152
Jan 30, 2014 1:54 PM
woody1
Dec 3, 2010 11:47 PM
hossler
Jan 15, 2010 5:50 PM
