Removing my Radio Disengage my Brake Sensor
Old Jul 29, 2009 | 8:49 AM
aboabady's Avatar
Default Removing my Radio Disengage my Brake Sensor
Hello ...
I have Chevrolet Suburban 2008,
When I removed the plug connector of my Stereo, The brake sensor red light comes on, and the sensor doesn't work, but when I return the plug back becomes OK.
How do I overwrite this problem when installing CLARION MAX386VD?
So many thanks ...
Old Jul 29, 2009 | 11:48 AM
SabrToothSqrl's Avatar
Default clarion
check crutchfield's web site; i think it needs an adapter?
no GPS?!
Old Jul 29, 2009 | 12:22 PM
shawnvw's Avatar
Banned
NEVER heard of this issue.....EVER.
Are you talking about the brake light, or the onstar light?
If it is the brake light, you have a problem
Old Jul 29, 2009 | 12:31 PM
aboabady's Avatar
I installed the CLARION MAX386VD and it's working fine, but the brake sensor red light still on, Need the P/N of the adapter to solve this problem ..
Old Jul 29, 2009 | 12:50 PM
aboabady's Avatar
Removing the network green wire of the stereo connector disengage my rear brake sensor witch the rear sensor indication becomes red all the time I go back, but when I place the wire back to the stereo the sensor work fine.
Now after I installed my CLARION the network green wire is not connected, I tried to connected to all the wires coming from the CLARION but no HELP!
Old Jul 29, 2009 | 5:50 PM
silverado_svc_body's Avatar
get the wiring diag. for the truck and see what it says.
Old Jul 29, 2009 | 8:29 PM
shawnvw's Avatar
Banned
something is fishy.....I d\c radios all the time from these trucks with the key on or engine running with no warning lights
Old Jul 30, 2009 | 1:11 AM
aboabady's Avatar
Default My Car Wiring Diagram
This is the wiring diagram of both (car stereo & clarion)
Plz. see attachment
Old Jul 30, 2009 | 6:07 PM
shawnvw's Avatar
Banned
Your comments at the bottom made more sense.....
You are talking about the reverse sensor indicator. NOT the brake sensor.
The radio controls the audible beep for the reverse sensors. Whenthe radio is removed from the circuit, it sees it as a fault.
The answer is to put an integration module into it as sabrtoothsqrl said.
http://www.pac-audio.com/productSear...x?keyword=os-4
Old Jul 31, 2009 | 3:41 PM
aboabady's Avatar
Thank u for all information that I got from u
silverodster
Dec 31, 2010 9:58 PM
woody2081
Apr 16, 2010 10:00 PM
TahoeMatt
Apr 23, 2009 8:23 AM
TWG
Oct 17, 2006 3:20 PM
TWG
Oct 17, 2006 3:19 PM
