Old Aug 10, 2015, 6:26 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Transmission Guides
Print Wikipost
Shudder or miss at cruising speed
Old Sep 9, 2021 | 8:15 AM
  #41
Jimmy Brideau's Avatar
Smile
Originally Posted by levi3
All my issues started after the injectors were replaced. I had the same issue, 2 things corrected it for me. The plinth was warped and had to be replaced, also the intake manifold gasket was replaced.
my 1994 Chevy with a 4.3 5 speed manual works perfect when the power to the SPEED BUFFER is disconnected...when power is connected to speedo my truck has a shudder when shifting gears and at cruising speed or just off idle...but works fine when on the throttle...I have changed everything you could think of and still same...I have not driven it in the last year because I haven't had time...I am going to try swapping the PCM next....I hope it works but if not I will just run it without speedo until I can figure it out...I have inspected wires but I may change the harness if the PCM swap fails
Old Feb 22, 2022 | 1:11 PM
  #42
CraigD98's Avatar
Question "Buck" for lack of better idea of description
Had new crate 5.7L and new transmission installed and now this problem. They thought it was happening when shifting but its actually not during shifting. I can be cruising at, for example, 50 mph for several minutes and all the sudden it "bucks" or what feels like a hard shift. No RPM drop or anything. Just a buck. they couldn't figure it out after checking everything possible and even sent back the transmission to manufacturer and got a new one because they thought they received a bad transmission. But that wasn't it. It did NOT do this before the new motor and transmission. So I am at a loss. I took the truck because they exhausted all possibilities and it otherwise runs fine; but I have 6 months left on my year warranty and am contemplating taking it back just telling them it is getting worse, so figure it out. BUT, I don't think they can. Otherwise I might take it somewhere else for some fresh eyes. Thoughts??
Old Feb 22, 2022 | 1:15 PM
  #43
CraigD98's Avatar
Old Mar 3, 2023 | 6:32 AM
  #44
jonathanl's Avatar
Default Any resolution yet?
This thread has been running for quite some time. I’ve got a ‘94 suburban doing the exact same thing now. Has anyone actually found a solution for this bucking at cruise issue? Like to hear your fix.
Old Oct 14, 2023 | 4:02 PM
  #45
Kevmore007's Avatar
Default Me to
I seem to have developed the same problem. Little single miss at part throttle. Sometimes a few in a row.
Schveb
Sep 18, 2017 9:05 PM
levi3
Mar 5, 2011 7:07 PM
levi3
Mar 4, 2011 9:45 PM
Overnite
Astro
13
Nov 9, 2010 6:48 AM
