Speaker whine and buzz Bose system???
2003 suburban
When you open the doors or hit a bump [sometimes when you're starting up with the radio off] the right side radio speakers will begin to whine and buzz. It sounds kinda like it's the warning system. The volume control does not raise or lower the loudness of the noise until you reach the "all the way off" position but the whine is definitely speed sensitive; not the buzz. Also the fader and the balance have no effect on the sound.
Where do I start to troubleshoot this??>???>?????>???
When you open the doors or hit a bump [sometimes when you're starting up with the radio off] the right side radio speakers will begin to whine and buzz. It sounds kinda like it's the warning system. The volume control does not raise or lower the loudness of the noise until you reach the "all the way off" position but the whine is definitely speed sensitive; not the buzz. Also the fader and the balance have no effect on the sound.Where do I start to troubleshoot this??>???>?????>???
I just bought a used 2005 and mine does it as well. ( whine - not buzz) Only fron the Rh side and I think only from the passenger door speaker and not the rear, but I have to double check. Changes in direct relation to the RPMs. Unfortunately I don't have a answer for you as I am trying to figure it out too but maybe some of the more experienced folks on here will be able to help us out. If I make any progress I'll let you know.
Thanks for the welcome and suggestions. Won't get to look at mine until the wknd. Was thinking of disconnecting that frt pass dr speaker and see if I still hear it. I'm trying to isolate the problem as much as possible. Is there any trick to to getting to that speaker or can I just pop that grill out of the door and get to it that way?
I am also missing the tweeter in the passenger pillar post if anyone knows where I can get one or of an aftermarket replacement that will fit correctly.
Randy - don't mean to hijack your thread. I can start my own on this if you like. Just was posting in here because we had the same problem.
Tom
Tom
If they build things to last forever a lot of use would be out of a jobs...and if they built them to last a long time the cost would trickle (avalanche) down to us buyers...its a balancing act by any manufacture for sure....
Hey Imposter,
Join in. It sounds like we have similar problems. I just made a four hour trip and could listen to my radio for only five minutes before the sounds began and they don't always start simultaneously. Sometimes the right rear starts first with no buzz, then the front kicks in [it's hideous and loud...louder than the radio]. I just don't know where to start the search for the culprit.
randy
randy
