Steering wheel lock question
Old Feb 17, 2008 | 8:54 PM
bimmerborn's Avatar
Default Steering wheel lock question
Hello folks,
Does your 2007+ Tahoe lock the steering wheel when you take the key out? Today I noticed mine does not do this. Is this only my truck or all are the same? I don't think Tahoe even needs this since when the enigne is not running the steering is hard as hell to turn. However I am curious. Thanks.
Old Feb 17, 2008 | 9:05 PM
07summitwhite's Avatar
Default RE: Steering wheel lock question
when you remove the key try turning the wheel all the way to the left or right, that should put it in the lock position.
Old Feb 17, 2008 | 10:33 PM
beden1's Avatar
My '02 Suburban does not have the steering wheel locking mechanism and I just took for granted the '08 Tahoe doesn't either. I thought GM eliminated this several years ago in all of their vehicles?
Old Feb 17, 2008 | 11:12 PM
Are you saying that your '07 wheel locks after key removal?
Old Feb 17, 2008 | 11:59 PM
bimmerborn's Avatar
ORIGINAL: 07summitwhite
Yes I tried 1/4 turn to the left and then 1/4 turn to the right. It did not lock. Does it lock on yours?
Old Feb 18, 2008 | 7:24 AM
I just checked and it dosn't lock. I thought it did. Why would they not want the wheel to lock?
Old Feb 18, 2008 | 10:14 AM
ZX1100F1's Avatar
The integrated steering wheel lock device was introduced in the 70's as another anti-theft measure, this device is no longer affective so it has been eliminated. GM has employed new PassLock anti-theft systems into the Tahoe which are more effective and less prone to malfunction.
Old Feb 18, 2008 | 7:39 PM
Was there ever an instance where one of the plastic teeth broke and allowed the wheel to lock with the key in the on position?
Old Feb 19, 2008 | 3:16 PM
ZX1100F1's Avatar
Steering wheels have locked up more times than you could shake a stick at, and that goes for all the manufacturers.
Old Feb 19, 2008 | 4:50 PM
I'll bet that's a cheap thrill if you're going down the hwy at speed. Probably have some extra laundry when you get home.
Tootallmech
Aug 7, 2023 11:49 AM
sledge.impy
Dec 6, 2013 8:55 PM
Mastiff
Jul 12, 2010 8:39 PM
LTZing
Apr 14, 2009 11:22 PM
dblastic
Mar 25, 2009 6:16 PM
