Transmission Fluid Level
Old Feb 25, 2014 | 8:40 AM
  #11
trainwreck91's Avatar
ok...thats why i'm baffled??? when its cold or off the level reads above full, not where the cold level is. when its running it reads at the cold level. and yes this is after running it for 15 min and driving about 10 min...
Old Feb 25, 2014 | 9:25 AM
  #12
'03 Heavy Chevy's Avatar
The transmission fluid should always show above the full mark when its off and cold.
Like Tech2 said, the cold mark is for checking the level when first cranking the motor. Its like a safety check to make sure there is plenty of fluid in it prior to driving it.
After driving it and getting the transmission fluid up to operating temperature, if the fluid level is low then add some more (in small amounts) until it reaches the full mark.
Old Feb 25, 2014 | 9:31 AM
  #13
Think of the transmission dipstick measurement method as checking the fluid level when the motor is running. The important part is checking the fluid while its hot and running.
This is opposite of checking engine oil. The dipstick is designed for checking engine oil with the motor off and having been off for at least 5 minutes (to let the oil drain back into the oil pan).
Transmission fluid measurement method is not equal to engine oil measurement method
Old Feb 25, 2014 | 10:18 AM
  #14
Thanks for clarifying that. That's what had me confused. The cold marker threw me off
Old Feb 25, 2014 | 10:20 AM
  #15
Sure thing!
jniolon
Oct 8, 2012 3:33 PM
raidrmark
Sep 15, 2012 4:35 PM
gaftop1
Oct 14, 2009 9:52 AM
Mud_Truckin
Sep 30, 2009 3:40 PM
Josephcweiss
Nov 23, 2007 4:41 PM
