Truck shuts off at traffic light or when it is in park for a while
Old Mar 28, 2021 | 6:55 PM
mztreseme1's Avatar
Default Truck shuts off at traffic light or when it is in park for a while
2005 Chevy Tahoe for the past two weeks has been turning off every couple days. One time at a traffic light, a couple days later when I was sitting in the driveway with vehicle running. It will start up; new fuel pump, alternator, ignition switch and battery. Any idea what this may be? Please help!!!!
Old Mar 29, 2021 | 7:28 AM
repairman54's Avatar
Check your main relays and look for any discoloration on their pins would be one thing to look at.
Relays can be erratic when the get old.
Dirty grounds are a issue also, there are many ground points.
Old Mar 29, 2021 | 10:59 AM
hanky's Avatar
If a crank sensor is preparing for retirement, that might mean it is opening up internally, that loss of signal would cause an engine shut down.
Does the engine stumble some before shut down or does just quit like you turned the key off?
Old Mar 29, 2021 | 11:43 AM
mztreseme1's Avatar
Quit like you turned the vehicle off
Old Nov 14, 2024 | 2:20 PM
xdheatherlynn's Avatar
Did you ever figure it out? Currently having the same problem I have no other symptoms
lb1569
Sep 25, 2014 6:06 AM
Jonrogers0760
Aug 8, 2011 11:24 AM
crxma22
Jun 3, 2010 11:21 AM
chevymalibu01
Mar 2, 2010 1:38 AM
efxr6wagon
Nov 19, 2009 2:47 PM
