Water Leak After Heavy Rain
Old Aug 5, 2022 | 4:07 PM
Wavelength's Avatar
Angry Water Leak After Heavy Rain
I have a water leak on drivers side in area of the parking brake. Anyone have a suggestion in what to look for? Thanks. Cheers, Wavelength.
2001 Yukon 5.3l.
Old Aug 5, 2022 | 5:48 PM
kevinkpk's Avatar
2001 Yukon 5.3l.
Try garden hose in that area, hopefully you can find it that way.
Old Aug 5, 2022 | 5:53 PM
Rednucleus's Avatar
Sun roof drain maybe?
Old Aug 5, 2022 | 6:51 PM
Also check your door weather stripping in that area.
Old Aug 5, 2022 | 7:06 PM
Wavelength's Avatar
Yea, I did that and the windshield tray is OK, no leak. When I put the hose directly on the plastic fitting, trim for where the hood hinges, that's where it will drip...alot.
Old Aug 5, 2022 | 7:13 PM
Wavelength's Avatar
The door weather strip looks very good. Also, no sun roof, although I did have some leaks around the roof rack, which are fixed now.
Old Aug 6, 2022 | 3:46 PM
Wavelength's Avatar
Talking Temporary Success
I pulled the trim off around the parking brake and saw water leaking from point A. Also, a weep hole at the bottom Point C. I cleared the weep hole and the water drained so no longer visible and leaking at point A. It collected in the channel under the trim, so I drilled a small hole at point B. This takes care of the water soaking the carpet until I can investigate further. The carpet gets wet in area D, soaking up from channel under trim. It isn't wet further up to the firewall. I suspect there is something leaking under the trim over the windshield runoff tray or there is another clogged weep hole further back under the step trim.
I have uploaded photos, but don't see them, sorry. Point A is a 1/2 oval 5" up the vertical pillar from the bottom under trim removed. Point C is the weep hole at the bottom of the pillar. Point B is where I drilled a hole at the front of the channel under the trim removed. Point C designates the immediate area around these points.
2001 Yukon 5.3l.
chevygirl2020
Apr 28, 2025 9:26 PM
chevygirl2020
May 30, 2020 10:33 PM
starsrocket
Jun 27, 2019 10:57 PM
billyboy
Jan 13, 2007 9:10 PM
