Whine from Radio on Startup and when gas pressed
Old Jul 3, 2007 | 11:02 AM
gcpurcell's Avatar
Default Whine from Radio on Startup and when gas pressed
I've just started having a whinning or buzz coming from my 03 Suburban LT. It seems to be coming from the radio. When I first start the car, it has a buzz in the speakers and then it quits, whether the radio is on or not. When I turn the radio on, it comes back and is more prevelant. The sound or speed of the buzz goes up and down according to whether I'm pressing the gas pedal.
We did just replace the fuel filter, and talk about a pain. Whoever had the bright idea to go to the design away from the 2 nut connection, has some problems in the head. Ended up having to cut the nipple on the filter and then was able to use the "tool" to get it out.
Was also wondering if this could be related to the fuel pump. I've read some of the other forums about the fuel pump problem. Mine, I found it thankfully while I was at work. If mine gets below 1/4 of a tank, it will not start back up. Once I get the gas level over 1/4, starts up fine. Any ideas would be greatly appreciated.
Greg
Old Jul 6, 2007 | 10:29 AM
gaftop1's Avatar
Default RE: Whine from Radio on Startup and when gas pressed
whine is usually a diode out in the alternator
Old Jul 6, 2007 | 11:13 AM
MalibuMaxxSS's Avatar
to my knowledge this is a common accurance on suburbans the fuel thing that is, all the ones I have drove besdie the newer ones die on cornering when below 1/4 tank, and wont start, if they are not level, pan in the ***.....the whine could be altenator, or bad ground the fuel pump change prolly wound not have caused it unless you clipped some stereo wires somewhere
Old Jul 11, 2007 | 8:03 PM
gcahal_az's Avatar
Its commonly referred to as altenator noise. They make filters for it was well that ties into the stereo wiring i used to get this alot on my older cars.
Old Jul 11, 2007 | 8:21 PM
golfer's Avatar
You can hear this sound through the speakers when the stereo is OFF ???
For all those saying the alternator... I would like an explanation to that one.
Old Jul 11, 2007 | 11:26 PM
gcahal_az's Avatar
Id love to TRY and explain it. But i cant I have the same thing going on in my work van. Its a 2001 2500. radio off and I get a faint whine in the speakers. And better yet my nextel radio/phone makes it go crazy right before it rings. the altenator noise has something to do with the grounding of the stereo and speakers and crap like that. Is it an aftermarket stereo deck? if so id say put on the filter for like 5 bucks and see what happens.
Old Jul 17, 2007 | 8:32 PM
golfer's Avatar
There are other sources of electrical noise other than the alternator such as faulty spark plug wires , fuel pumps and other electric motors.
Old Sep 20, 2007 | 3:25 PM
08silveradonb's Avatar
i will tell you all now, this is due to a bad ground connection. dont go get a noise filter, you need to track down the grounding points you messed with when replacing fuel filter, and make sure they are making good contact. make sure they arent loose, or corroded. im 99% sure that its the ground. dont believe a noise filter will fix the problem, not only that why go spend money, if all it takes is a wrench (i assume you already have that)?
Old Sep 23, 2007 | 6:42 PM
350Suburban's Avatar
Does this happen on am or fm stations?
Old Sep 24, 2007 | 10:07 AM
golfer's Avatar
ORIGINAL: 350Suburban
The claim is it can happen with the radio off.
randyehughes
Sep 29, 2019 9:58 PM
usahoe18
Nov 28, 2012 8:09 AM
gianelli280
Sep 28, 2009 10:58 PM
junL
Mar 14, 2008 7:42 PM
randyehughes
Jun 7, 2006 5:56 PM
