1999 Suburban Roof Rack Removal
Old Aug 23, 2013 | 4:07 PM
weaver07950's Avatar
Default 1999 Suburban Roof Rack Removal
Is the roof rack a standard Chev Suburbvan option? It is fastened down with Torx T-25 screws. If I remove them will I lose the connecting nut or other fastener in the roof, or is it fixed in the roof. In other words, is it properly designed to remove and re-install?
Carl
Old Aug 24, 2013 | 2:57 PM
Welcome to the forum.
I don't know for sure but expect Chevy uses Well Nuts to attach the rack with. In which case you can remove the rack from the outside.
Old Sep 14, 2013 | 5:50 PM
Captain Obvious's Avatar
Assuming you figured it out, but will tell you what I found when removing mine.
I decided to add an additional cross member and had to replace the rack as a whole, so grabbed the torq and went to town.
I found that a couple of the well nuts were just tired and shagged and would spin freely. Also had one or two that were rusted out and couldn't even keep the well nut in. I had to punch a couple in adn haven't had any issues with hearing them bounce around etc.
gnicolai
May 19, 2012 9:59 PM
azeller22
May 15, 2012 3:16 PM
jax.fl.79
Jul 25, 2011 10:07 AM
GeeDubb
Apr 28, 2010 8:07 AM
mary900
Jul 30, 2008 10:00 PM
