Tracker 1989-2004
Platform: CAMI (Suzuki)
2001 A44DE Tran Fitting Washers?
Old Jul 17, 2021 | 4:51 PM
code636's Avatar
Default 2001 A44DE Tran Fitting Washers?
Tried looking everywhere else. Wife has a 2001 Tracker, V6 w/ 4wd. The A44DE transmission lines fittings, are leaking past the spacer/washers, Part #96068418, and am unable to find any info on them anywhere. The factory fittings are Banjo type. Both front and rear and constantly dripping and coated the floor, right by the exhaust. Needless to say, that aint good. Am located outside Savannah,GA. Anybody know a better part number and/or where to locate a replacement set? Thanks in advance
Old Jul 17, 2021 | 6:19 PM
L84sky's Avatar
Amazon has a pack of 10 for $7. Free shipping on $25 order.
Amazon.com: Primeonly27 14x20x1.5mm Copper Washer Oil Drain Plug Gasket 10 Pack: Automotive Amazon.com: Primeonly27 14x20x1.5mm Copper Washer Oil Drain Plug Gasket 10 Pack: Automotive
Looks like you need four of them.
Old Jul 17, 2021 | 7:25 PM
code636's Avatar
Unfortunately, that's way off sizewize. Ones you listed are 14mmx20mmx1.5. Like 100% too large. According to chevy site, the bolt/screw size is 1.4mm, the i.d. for washer is 1.5mm, and thickness is 0.2mm.
Old Jul 17, 2021 | 7:44 PM
L84sky's Avatar
I'm confident the Chevy data you have is wrong. Here is easy way to prove it. Use an adjustable wrench as a poor man's caliper. Set the wrench opening to match the OD of the washer. Remove the wrench and measure the gap. I'm sure you will see that it is 20mm. The ID should be 14mm which is the same as 1.4cm.
These are the copper washers for the power steering banjo bolts. They are good sized washers.
Old Jul 17, 2021 | 7:56 PM
L84sky's Avatar
The copper gaskets on the power steering pump are not the same size as the transmission but they are close.
Here are the dimensions (in mm's) for the GM part number you provided.
Turns out it's the same size gasket on your oil pan drain bolt.
Old Jul 17, 2021 | 9:02 PM
code636's Avatar
Will check when she gets home in morning. The power steering bolts are the same as the transmission lines? If so, might be able to get those and swap out on the tran lines. Thanks
Old Jul 17, 2021 | 9:08 PM
L84sky's Avatar
No! The power steering banjo bolts are not the same size as the transmission bolts. I just had picture of the P/S bolts to indicate their relative size. Do not remove the P/S bolts. Just get the correct copper gaskets from Amazon.
Old Jul 17, 2021 | 9:12 PM
code636's Avatar
If the p/s lines washers can be opened up a little to match, should work. Those should still be available I'd think. I'll start looking for now.
Old Jul 17, 2021 | 9:23 PM
code636's Avatar
Ok. Wasn't going to take p/s bolts off, was going to track down a new set and see if those would work. Know better to cannabilize working part and permanent mod it and not work and now have 2 problems. will check out tomorrow, if necessary, take old one off and use calipers on it.
Old Jul 18, 2021 | 5:32 AM
L84sky's Avatar
I would just buy the correct size (14x20x1.5) copper washer from Amazon. If that is not an option these aluminum washers from RockAuto are also 14x20x1.5
