Tracker1989-2004
This compact SUV proved itself to be a fine ecnomical vehicle, good for making its way along any type of surface. Platform: CAMI (Suzuki)
2.0 liter 4 cylinder 2003
No parts store can help me. A torque converter bolt came loose and got caught in the flywheel and tore everything all to hell. Got another motor and am installing it. Found some bolts that fit, had to trim them down... I would rather have the bolts that are meant for the job so I can make sure to torque them properly. I cannot find the proper torque converter bolts anywhere. The nearest salvage yard that has one is 2.5 hours away and they can't even tell me if the transmission is still in it or not. Any tips or experience on this is appreciated.
Just to update this thread: the two flex plate bolts are NOT the same. The type 1 bolt is used to center the flex plate on the torque converter. The type 2 bolts hold the flex plate in position.
Type 1 bolt on the left. Type 2 bolt on the right.
