Tracker 1989-2004
Platform: CAMI (Suzuki)
Electrical issues 2004 Silverado Z71
Old Apr 25, 2019 | 11:07 AM
Silverado2004's Avatar
Unhappy Electrical issues 2004 Silverado Z71
I have a 2004 Silverado Z71, 4WD, 5.3L, Extended Cab with electrical issues. It began with the radio time resetting to 12:00 am when i would start the truck and continues to this day. This later escalated to when turning the key the truck would start intermittently and when it didn't start there would be a clicking sound which was from the starter. Even later on when turning the key to the auxiliary position the dash lights might come on or just the check engine light and it would be dim and there would be no sound from starter when turning the key.
What i have done so far: Checked battery, Changed ignition switch, changed starter, cleaned ground wires on frame below drivers door, checked wires on throttle body (i did received a "low engine power") from dash display but only once during the last month or so since having the problem.( i changed the O2 sensors last year) I have read various posts on the same issue but with the changes i have had made it's still is not fixed. That said after changing the starter the truck will start after a couple of attempts (new starter still clicks on initial couple of try's). And once started it will start every time without clicking yet the clock will reset to 12:00 after every attempt.
Codes i have received: P0120, P0220, P1516 these came in January but i have not had these come up again. At my wits end! Any help would be appreciated.
Rgds ... Barry
Old May 15, 2019 | 11:13 AM
Issue resolved. Had the battery load tested and told it was fine but this was from the top posts only and not the side posts in other words how it is connected to the truck. The end result was the side post/s was faulty causing bad connection at times. Battery was a Sears model so won't be buying this brand again ... oh wait they are no longer in Canada so no worries
Wish i would have looked at that at the beginning myself. Oh well live and learn.
Old Dec 17, 2021 | 2:42 PM
Ttucker96's Avatar
Rgds ... Barry
Hey, were you able to troubleshoot what was wrong with your truck? My 2004 cateye is having the exact same issue.. Any advice??
Thanks!
Old Jan 1, 2022 | 11:09 AM
Thanks!
Actually took my truck to a mechanic. The battery has both side and top posts and when i took it to get load test done (they do them for free at this service center) they only checked the top posts which were good but i did not use top posts i used the side posts. So long story short after checking everything i possibly could it was simply a faulty battery post that was the issue. When i got the load test completed i should have told them to check both side and top posts but you would think they would have done that.
krivs388
Sep 16, 2021 10:04 PM
Robin Werner
Jan 6, 2020 10:04 AM
Uknowjoe
Mar 17, 2018 8:50 AM
Restlessone
2007 - 2013 (GMT900)
May 20, 2016 12:26 PM
indy
Feb 16, 2010 9:16 PM
