Random no start need help
Old Jan 5, 2020 | 1:30 PM
Robin Werner's Avatar
Default Random no start need help
I have a 2003 chevy Silverado 1500 with 5.3 vortec 223000 miles on it I have been haveing a intermittent starting issue when you turn the key over it clicks it's very random I have come to notice that it does it more when the truck is parked in the sun for a period of time like something is getting hot sometimes if you hold the key in start postion it will eventually start then wont do it for a month or so new relay new battery no codes tried different key checked grounds and wires on starter all good n clean I've heard alot of people had this issue but never heard a fix any ideals will be appreciated thanks
Old Jan 5, 2020 | 1:34 PM
kevinkpk's Avatar
What's the history on the starter?
Old Jan 5, 2020 | 1:37 PM
as far as i was told it was replaced 2 years ago .
Old Jan 5, 2020 | 2:19 PM
kevinkpk's Avatar
Does it sound like it is dragging? What you describe hearing is a solenoid issue. These are not hard to replace, and are very light weight compared to old versions. You might try just replacing the starter solenoid if it's not dragging.
Old Jan 5, 2020 | 2:33 PM
When you hold key to start ""when it acts up "" it sounds like not enough volts from battery clicking then all of a sudden it might and might not start till you mess with it a bit it is very random I've read about ignition tumblers sometimes so I changed keys still randomly does it and sometimes I have noticed the security light is on very dim in dash but usually dont effect anything as I know of its random also but I will try the starter first just read alot of people dont have much luck with starter and intermittent starting but I'll go that way thanks
Old Jan 6, 2020 | 7:30 AM
Have you checked both battery cables? Do they have tight connections with no corrosion at both ends?
Old Jan 6, 2020 | 8:03 AM
. Yes I have even went around the truck and cleaned all grounds I could find ..engine to frame and frame to body ..
Old Jan 6, 2020 | 9:55 AM
Rednucleus's Avatar
Sounds like time for a new starter
Old Jan 6, 2020 | 10:04 AM
. I have one coming this week due to them being 200 $ at local parts store and hearing alot of similar stories of random no starts and them replacing starter with same issue afterwards I was trying to see if anyone found the solution there is alot of threads on net with same issue but with it being random you never know if it's fixed untill it happens again Chevy has had a issue with this in Silverado and avalanches since 2001 ...
cterry0831
Feb 13, 2019 11:17 AM
Restlessone
2007 - 2013 (GMT900)
May 20, 2016 12:26 PM
badmystur
Feb 25, 2015 8:47 PM
ivbutch
Feb 19, 2013 9:51 PM
paradice01
Jul 5, 2007 5:11 PM
