Tracker 1989-2004
Platform: CAMI (Suzuki)
How do you remove the ignition cylinder
Old Mar 6, 2025 | 9:48 AM
Chiefchris's Avatar
Default How do you remove the ignition cylinder
Trying to replace my ignition switch and cylinder on 2002 tracker how do you remove the bracket holding it in place looks like 2 Boltsit’s machine in with no way of removing them
Old Mar 6, 2025 | 1:33 PM
L84sky's Avatar
Those are security bolts. The heads shear off during installation. Most people use a chisel to back them out. You can try cutting a slot in them with a Dremel tool or welding on a dimple if you are brave. They will come out with enough patience. Also, there are different ignition switch part numbers for automatic and manual transmissions.
Old Mar 9, 2025 | 5:18 PM
L84sky's Avatar
I remembered seeing this video a few years ago. I was able to find it today. Fast forward to time 8:55.
Mkiker2
Jul 10, 2024 8:39 AM
abunai23500
May 9, 2022 8:07 PM
Purple Power Ranger
Jun 22, 2020 10:03 AM
MellyMel2186@hotmail.com
Oct 20, 2014 11:19 AM
retho78
Jun 1, 2010 4:20 PM
