Tracker1989-2004
This compact SUV proved itself to be a fine ecnomical vehicle, good for making its way along any type of surface. Platform: CAMI (Suzuki)
Trying to replace my ignition switch and cylinder on 2002 tracker how do you remove the bracket holding it in place looks like 2 Boltsit’s machine in with no way of removing them
Those are security bolts. The heads shear off during installation. Most people use a chisel to back them out. You can try cutting a slot in them with a Dremel tool or welding on a dimple if you are brave. They will come out with enough patience. Also, there are different ignition switch part numbers for automatic and manual transmissions.
