Tracker 1989-2004
Platform: CAMI (Suzuki)
No start
Old May 21st, 2024, 1:14 PM
  #31
MoterMitch's Avatar
definitely looking for a scanner, thanks for the info! OK so I managed perform the injector current test I think I did it correctly, Put the clamp around the positive wire on the injector? it yielded no reading? 12 volts key on to injector. thoughts?
Old May 21st, 2024, 1:56 PM
  #32
L84sky's Avatar
This is the fuel injector diagram for a 2001 four-cylinder. The Main relay should energize when the ignition switch is in RUN. That should provide 12 volts to the top of all four injectors. The injector will energize when the PCM supplies a ground. Try to back-probe one of the pink wires on the injector connector with a jumper wire. Tap the jumper wire on some metal part of the engine. You should hear the injector pulse. Turn the time/div selector on your scope to the something like 1 sec/cm. See if the current probe will display the current pulse when you tap the ground. Don't tap too many ties in a row or you will hydro-lock that cylinder with liquid gasoline.
Old May 22nd, 2024, 10:18 AM
  #33
MoterMitch's Avatar
ok my attempt's to back probe the injector connection, with my Harber freight probe set feels like I'm damaging the injector connection. unfortunately, my schedule wont allow me to work on it for two days . what was the name of the scanner you bought SKY ? TECH 2 CLONE i looked on ALI EXPRES NO LUCK!
Old May 22nd, 2024, 10:33 AM
  #34
Pierregirard's Avatar
Use a multimeter to check the sensor's resistance and compare it to the manufacturer's specs. You can also use an oscilloscope or a diagnostic tool to check the signal from the CPS while cranking the engine.
Old May 22nd, 2024, 10:36 AM
  #35
MoterMitch's Avatar
got it thank you !!!
Old May 22nd, 2024, 11:12 AM
  #36
L84sky's Avatar
Wow! They seem to be harder to locate now but I found this one. I have messaged them asking if they can provide the GM module. I'lll let you know what they say.
6 model OBD2 Diagnostic Scanner with TIS2000 CD ROM Flash Tester Replacement For OPEL English 165 1997‑2014 Car Diagnostic Tools (aliexpress.us)
Old May 24th, 2024, 6:34 PM
  #37
MoterMitch's Avatar
I need a scanner that deals with cars from 2010 and back, I am looking for your advice at getting my best bang for the buck.
Thanks again.
Old May 24th, 2024, 6:46 PM
  #38
L84sky's Avatar
If the car is older than 1996 it won't be OBD2 compliant. If the car is anything other than a General Motors vehicle you don't want the Tech2 scanner I have. Autel has several $500 scanners but I haven't done enough research to make a recommedation.
Autel scanner
Old May 25th, 2024, 5:53 AM
  #39
MoterMitch's Avatar
2001 tracker,1998 Astro, the rest Toyota. Or Ford.
Old May 25th, 2024, 7:30 AM
  #40
L84sky's Avatar
Watch the video in post #30. Ivan says the best deal is a Launch X431 or an Autel MaxiCom MK808TS. I don't know which is better.
Quick Reply: No start
