TrailBlazer 2002-2009
Fan clutch not engaged until engine is 200 degrees.
Old Jun 21, 2022 | 4:53 PM
  #11
flyboy2610's Avatar
Originally Posted by VaDreamer
Honestly, I am contemplating just putting a switch in to lock the fan manually and see if that corrects the issue.
Please be very careful if you do this. The throttle body shares a 5 volt reference signal with the fan clutch, and if that signal becomes degraded the ECM will put the truck in Reduced Engine Power mode, and you will be limited to 5 mph. The ECM does this because it no longer knows exactly what the true position of the throttle plate is, and it basically shuts down the throttle body to prevent a runaway situation.
Some people have replaced the fan clutch with an electric fan, but then the ECM needs reprogrammed to make it work properly. I've not done this myself, so I don't know exactly what's involved with it.
I believe the later model TB's ('07-'09) had a thermal fan clutch rather than an electronic one, so you may be able to use one of them. Again, you may need the ECM reprogrammed to make it work. I honestly don't know about that, though.
Old Aug 14, 2022 | 3:53 PM
  #12
PappyGoodwill's Avatar
New User
Awaiting E-mail Confirmation
We gave up on that fan crutch business. I got an electric fan and bolted it in the shroud. Now, I'm in the process of running down schematics to see which wire is hot with the key.
William Wills
1988 - 1998 (GMT400)
Aug 14, 2022 3:58 PM
subfan597
Jul 14, 2018 2:54 AM
pdrayton
May 29, 2013 7:55 PM
L5wolvesf
Feb 20, 2013 4:17 PM
jiggsy
Oct 4, 2007 12:01 PM
