Uplander 2005-2009
Platform: U-Body
2008 Uplander TCS/ABS lights come on right turn
Old Jul 12, 2020 | 1:50 PM
707mjanes's Avatar
Default 2008 Uplander TCS/ABS lights come on right turn
Hello,
Have a 2008 Uplander that the TCS and ABS lights come on whenever I turn the steering wheel rightward past centered (straight ahead). Doesn't happen on a left turn, or on a right turn until the wheels are pointing slightly right of center. I had the right wheel sensor replaced at a shop that's been trustworthy in the past, and that did not fix the problem. I inspected the connection at that wheel and everything looks OK; even took a small rat-tail file to the contacts and again, no change.
I was able to obtain the following codes on my OBDII scanner that seem relevant to the issue: C0041, RF wheel sensor circuit range/performance, C0040 RF wheel speed sensor circuit malfunction, and C0253, Centering fault. Are any of these relevant, and if so, where should I start looking for issues? Finally, might this be a steering wheel position sensor problem? Any helpful advice would be great.
RickR90s
2007 - 2013 (GMT900)
Jan 30, 2020 8:00 AM
AJDre
Nov 9, 2018 11:34 PM
AlexLok96
Uplander
17
Aug 4, 2017 11:09 AM
batman4ever
Uplander
Oct 10, 2016 4:53 AM
cbe295
Jan 19, 2013 10:11 PM
