Uplander 2005-2009
Platform: U-Body
Slow coolant leak ....
Old Jun 17, 2011 | 3:18 PM
Papa Bear's Avatar
Default Slow coolant leak ....
My '07 Uplander (40k miles) recently started leaking a small amount of fluid under the motor. I had the van undercoated recently and thought it might just be dripping a little. Today I got under the front end and felt a drop of the fluid.. it was Dex-cool. I touched a drop to my tongue and it tasted quite sweet, coolant for sure. The dealer confirmed this afternoon that the crossover pipe was leaking ( TSB #07-06-02-006A ) and will be fixed next Tuesday under warranty.
Old Jun 21, 2011 | 12:38 PM
Papa Bear's Avatar
Picked up the van at lunchtime, looks and runs like new.
They put in fresh Dex-Cool. I'll monitor for leaks and/or coolant loss and keep you posted.
Old May 9, 2014 | 9:28 AM
niceguy88's Avatar
3 year bump alert !
I asked permission from PB to bump this as a form of update on the ever abundant coolant crossover pipe gasket leak.
So Papa Bear, it's been about 3 years since the leak was fixed-is the leak still fixed? I've read many complaints that dealership crossover leak repairs reappear after a year or two so I'm just curious, thanks buddy.
Continue reading for personal dealership rant:
My 2008 Cargo Uplander has a slow small leak at the back of the crossover pipe. Unfortunately the van is out of warranty and the local dealership, after charging me $110 for diagnostic, aka simple pressure test!-was adamant that the water pump was leaking and nowhere else.
I asked them how the water pump, which is front and low on the engine could be the source of the leak when the coolant is high and rear on the engine, a known TSB trouble spot. They had no answer.
Well a longtime friend is a 30year pro mechanic and did his own pressure test. Whaddayaknow?? No leaking water pump at all, not even at the weep hole!
His observation- Dealership attempt to charge for water pump replacement then call me to say "Oh! You're right, there is ALSO a crossover pipe (or head gasket depending on their level of crookedness) that we'll have to replace while you're in here already". Really ticked off at GM at this point so we'll be changing the crossover gaskets ourselves soon.
Old May 9, 2014 | 12:21 PM
Papa Bear's Avatar
No leak so far .....
Did a coolant drain & fill last summer (2013) and all seems well under the hood.
Old May 11, 2014 | 2:27 AM
sciaky05's Avatar
New User
Awaiting E-mail Confirmation
Default Intermittent Coolant Leak
My 2008 Uplander has had an intermittent coolant leak for the last couple of years. There will be about a 1/4 cup or less of coolant on the radiator shroud directly in line with the serpentine belt. It is never on the back side of the engine on the firewall. I have washed it off and looked for a leak several times. It may do it twice in week, or I may go months without seeing any. I have added about 2 quarts of coolant over the last year. I thought it would be the water pump, but like I said I haven't been able to find where it is coming from. Any ideas? The vehicle has 103,000 miles on it and it is time to change the coolant, but I would really like to fix the leak first.
Old May 11, 2014 | 6:16 AM
Papa Bear's Avatar
Did you have the coolant system pressure tested?
Old May 11, 2014 | 9:04 AM
sledge.impy's Avatar
Autozone might have one for borrowing
https://www.google.com/search?q=stan...ressure+tester
Old May 11, 2014 | 1:24 PM
sciaky05's Avatar
New User
Default pressure tester
No just checked it while it was warm and running. I will check with the local auto parts store and see if they have one to loan.
Old May 12, 2014 | 7:55 AM
niceguy88's Avatar
I should get mine back this evening, I just didn't have the desire to tackle this myself.
But one of the metal/rubber crossover pipe gaskets did have a ruptured o ring insert causing the slow leak.
Old Oct 26, 2015 | 10:43 AM
Shawn Mahoney's Avatar
Default Did you find the leak source?
Did you find out where it was leaking?
dlaroche
Oct 29, 2014 7:17 PM
BurbanMCS
Apr 20, 2013 12:38 AM
95wt
May 30, 2008 3:07 PM
shakedown88
May 16, 2007 6:36 AM
bc56845
Nov 29, 2006 2:12 AM
