Uplander 2005-2009
Platform: U-Body
Uplander P0172 code
Old Jan 8, 2014 | 7:04 AM
princej's Avatar
Default Uplander P0172 code
hi,new year, new problem with the uplander.
my check engine light is coming on, and my code reader says its a p0172. rich condition at bank 1.
ive researched it as best i can and it can be the maf, oxygen sensors.
i removed the maf, and cleaned it well. i verified that its working, so i pretty much ruled that out.
anyone see this code before? tips on getting rid of it without throwing tons of money at it.
thanx all.
Old Jan 16, 2014 | 7:58 AM
princej's Avatar
im still struggling with this.
i have more info if anyone can help.
my long term fuel trip is -24 on average.
Old Jan 16, 2014 | 12:49 PM
Papa Bear's Avatar
What year is your Uplander?
How many miles/Kms on it?
It is hard to know your situation if you don't share that "more info" ...
A quick Google of "p0172 Chev uplander" brought up pages of hits.
Good luck.
Bob R
Old Jan 16, 2014 | 7:43 PM
assuming you have an 08.
cleaning the maf usually does not fix bad maf sensors. It may be sending signals but they could be skewed...imo no way to know that by looking at scan data unless you have a second vehicle to reference.
this condition can only be caused by:
bad 02 sensor
bad maf
high fuel pressure
leaking purge solenoid
skewed OH sensor if you have a flex fuel vehicle
possibly a bad map sensor
so check your fuel pressure with a fuel pressure gauge first as this is the easiest to rule out. if your scan tool will show the OH sensor what is the value? If its anything over 10% that's your problem...reset it to 0
Old Jan 17, 2014 | 6:39 AM
princej's Avatar
its an 2008 with 75,000 km's
bought new and well cared for.
maf has been checked. o2 sensors have been bought, but its unlikely that.
I do have flex fuel.
thanx for the post tech2, excellent advice, its well appreciated.
Old Jan 17, 2014 | 6:53 AM
02 sensors?....this car only uses one precat 02 for fuel trim control. replacing the post cat sensor for this issue would be a complete waste.
if you have a method to check mafs other than replacement...I would love to hear it.
Old Jan 17, 2014 | 6:59 AM
princej's Avatar
hi, then I got some mis information from my parts supplier. as he said there was 2.
you sure there is only 1 - o2 sensor before the cat. you have any diagrams i can check?
Old Jan 18, 2014 | 9:52 AM
princej's Avatar
hi, heres the latest.
your right , it turned out to be the maf.
got a new one and it solved the current problem. light is off, car is running smooth as silk.
thanx to tech2 for his help.
Old Jan 18, 2014 | 10:20 AM
Papa Bear's Avatar
Cool
Right on !! They don't call him tech2 for nothing .....
Old Jan 18, 2014 | 11:18 AM
princej's Avatar
no, I spoke too soon.
light came back on.
