Venture 1997-2005
Platform: U-Body
2000 Chevy Venture Low Coolant Light
Old Jan 5, 2007 | 6:46 PM
reelcharacter's Avatar
Default 2000 Chevy Venture Low Coolant Light
Greetings,
New to this site, but unfortunately not new to car problems. Hope someone can help with a question I have about my 2000 Chevy Venture.
On a recent trip my Low Coolant Light came on. I added 1/2 gallon or so antifreeze to the fill reservior. Resumed trip and light came back on after a while, temperature stayed good and antifreeze was still in the reservoir. Resumed trip right away and light stayed off for 1/2 hour, then came back on again. Around town for the last week the light has not come on at all and fluid level has been good in the fill reservoir.
What could be the cause for the light to come on perodically? It only seems to come on after some time driving at 65-70 miles per hour.
Is a new radiator cap in order or perhaps a new fluid level sensor?
Is thispossibly an indication of something more mechanical (and expensive) that I will have to deal with?
PS I Have to head out on a 3 hour trip tomorrow . . . wish me luck.
Thanks in advance for any help and info you may have.
Old Feb 25, 2007 | 6:48 AM
x9er2's Avatar
Default RE: 2000 Chevy Venture Low Coolant Light
I've had the same problem but as soon as i had the sensor replaced, the problem was solved.
Old Feb 25, 2007 | 4:37 PM
shnormo's Avatar
Dex cool tends to gum up and that's why the lever sticks. The only really way to fix it is to change that float sensor.
Old Jul 19, 2007 | 8:05 PM
Just a follow up. My worst fears were realized after the van began running rough. Spent good money to have plugs replaced and a tune up. Then discovered the vehicle had a head gasket leak and needed a $2,000 engine replace,emt.
-reelcharacter
Old Jul 20, 2007 | 9:36 AM
golfer's Avatar
That's unfortunate news but not uncommon.
That would explain the coolant loss but not why the low level light being on.
Old Sep 5, 2010 | 12:16 AM
Derl's Avatar
Default Me Too
yes, I would like to know where the low coolant light sensor is also. Someone please tell us.
Thanks In advance,
Derl
Old Oct 1, 2010 | 6:39 PM
bigbrakeparts's Avatar
I spent $110 for a factory repair manual next day I bought the car. Saved me at least 20 times or even more.
The sensor is on the radiator on the passenger side and it is facing the accessories belt. There is a clip which needs to be removed. Access is reasonable. Pull sensor strait out. Clean the gunk and reinstall.
Old Oct 2, 2010 | 7:53 PM
Derl's Avatar
Thanks, BigBrakeparts, for the reply. I'll do it next week.
s2002h69
Nov 11, 2010 5:32 PM
sonkitty
Jun 5, 2009 11:52 AM
cbr600rrnut
May 5, 2008 12:12 PM
cdella
Nov 5, 2007 2:06 PM
