Venture 1997-2005
Platform: U-Body
2002 Chevy Venture cranks and will not start
Old Aug 21, 2015 | 6:53 AM
  #11
chevy47390's Avatar
if the fuel pump has been running without fuel, it is most likely to be deteriorated.
The fuel pressure should be close to 25 or 30 PSI on the injectors (2bars)
this is where to look for.
Old Aug 21, 2015 | 8:19 AM
  #12
dougsbart's Avatar
It did start and run indefinitely without a code. But I would have to "reset" it every time by completely disconnecting the battery and then reconnecting. The crank sensor was not bad, one of the wires on the plug was broken. I put a new pigtail on the plug and that fixed the problem. I would check your injectors while cranking the engine with a noid light.
92spi
Mar 7, 2015 3:59 PM
bluedrew5091
Jun 25, 2013 12:00 PM
likitysplit
Feb 3, 2013 9:14 AM
KunoCorp
Jan 24, 2011 2:19 PM
hellspawn4001
K5 Blazer
Feb 14, 2010 5:37 PM
