Venture 1997-2005
Platform: U-Body
Venture 98' Rear Power Windows Issue
Old May 28, 2012 | 6:56 PM
Tegnus's Avatar
Question Venture 98' Rear Power Windows Issue
Hi Guys,
I have had this issue for a while, but I did use a simple solution always - leave them closed, as summer is approaching I would like to fix this.
So problem is very basic both rear power windows doesn't work consistently. They can work fine one day and they will not work on next. Or they can open just fine, but they will not close. Or one will open, second will not in no particular order.
Basically those things are super unreliable. Do you have any suggestions to fix it?
Thank you!
Old May 29, 2012 | 5:23 AM
johntaps's Avatar
Former Sponsor
Post Venture 98' Rear Power Windows Issue
Sounds like the switch to me....could be a bad relay?
Old May 29, 2012 | 11:28 AM
Tegnus's Avatar
When I take it off the Window - detach it, motor works fine in both directions.
Can it still be bad relay that doesn't pass trough enough electricity? Old motor that doesn't have enough power? Other Ideas?
Thanks!
Old May 29, 2012 | 12:26 PM
Another possibility is loose or bad connections at the switch and/or the motor. Check as much of the wiring as possible for worn insulation or weak spots in the wiring.
Old May 29, 2012 | 2:31 PM
Tegnus's Avatar
Have checked both ends quite a few times.
Is there parameters I can check for with multimeter? How many Volts should be in the wire?
Thanks!
Old May 30, 2012 | 3:48 AM
12 volts
Old May 30, 2012 | 4:28 PM
Tegnus's Avatar
12 volts
Measured on of two motors and it has about 12.8V coming in when engine is running, but it doesn't work with Window attached to it. When it's detached works just fine.
Tried to grease all moving parts so that there is minimum of resistance when motor moves, but it didn't help.
Thinking about changing motors to manual latches so that there is some reliable, old-fashion windows opening mechanism...
Old May 31, 2012 | 12:21 PM
Tegnus's Avatar
Went to auto wrecker and they told they are not selling latch alone. I guess those windows will have to stay closed until I figure out how to solve this issue...
knarly gto
Jul 6, 2013 8:00 AM
Nancy212
Cobalt
Nov 21, 2011 2:19 PM
spedaleden
Sep 11, 2011 2:03 PM
Venture_Mike
Oct 20, 2010 4:51 PM
sidewayzpimpin
Jun 12, 2007 6:40 PM
