01 chevy 2500hd head gasket problems
Old Apr 14, 2016 | 11:20 AM
Sdub419's Avatar
Default 01 chevy 2500hd head gasket problems
Tryin to figure out the generation of my engine so i can get a replacement head gasket. Rockauto has different opinions. Not sure what one to get. Can anyone help?
01 chevy 2500hd head gasket problems-20160310_150704_716bebe61de6226af90a1c9bf1d26b0ab130be91.jpg
Old Apr 16, 2016 | 11:51 PM
cleveland63b's Avatar
you should be able to tell from the rpo codes in the glovebox
Old Apr 17, 2016 | 6:54 AM
COSMOS's Avatar
Just perusing the internet, grade C gaskets and most guys that do head gaskets have the heads machined (always a good idea), some even install ARP head studs as they are going to or have the truck tuned or already tuned it, lots of information on DuramaxForum, Duramaxdiesels.
Old Apr 17, 2016 | 10:30 PM
would be nice to know if its a duramax or not also
Old Apr 19, 2016 | 11:11 AM
COSMOS's Avatar
Not sure of your question.? GM 2001 to current uses the Duramax diesel engine only in the 2500HD and 3500HD trucks, they also used it some of the medium duty trucks. 2001-2010 use the same gaskets although a change was made in 2006 and all replacements are this style and come in A B C thickness.
DuramaxDiesel-EOM-030812-p1.pdf
Old Apr 19, 2016 | 1:41 PM
just because its a 2500hd doesn't mean it has a duramax in it
Old Apr 19, 2016 | 1:46 PM
COSMOS's Avatar
Let me clarify if you did not understand what I wrote, the Duramax engine is the ONLY DIESEL engine in the 2001 to current used in the 2500HD 3500HD trucks, 2000 and prior were 6.5 and 6.2 diesel engines and used in the 2500, 3500 as well as 1/2 ton trucks. GM also installed a 8.1 liter GAS engine with an Allison transmission in the 2500HD and 3500HD for a few years. Yes there were other engines used in the 2500HD and 3500HD trucks 2001-2010, the most common was the 6.0 Liter GAS engine...........
Old Apr 20, 2016 | 1:28 PM
which was exactly my point
Old Apr 20, 2016 | 5:14 PM
COSMOS's Avatar
Attachment 8996
RPO codes on the glove box door and check them in the PDF link below will give you all the information for the truck....
rpo.pdf
