Chevrolet Avalanche
Platform: GMT 805 & 900
Strange airbag sensor issue - looking for experience
Old Dec 26, 2023 | 5:33 AM
Extinct's Avatar
Default Strange airbag sensor issue - looking for experience
So I have the common airbag sensor fault, swapped left and right and confirmed bad sensor as the fault followed the sensor. I have the 25896408 sensors. So the strange part is that my sensors do not have the keyed slots on the inside of the sensor like all the ones I see available on the internet, mine have nothing in the female socket. The problem of course is my plugs will not go in to the keyed sensors (I obtained several at the junkyard to try).
Internet sensors
My sensors
Two of my junkyard sensors are similar, same pn on the label, but different plug configuration. Unfortunately I do not have a 25896408 with the correct plug configuration and have not seen any online with the correct one. Local Advance was similar to all the ones I see online as well. Anyone else run in to this? Is there a solution other than replacing the plugs?
Old Dec 26, 2023 | 4:27 PM
https://www.gmpartsgiant.com/parts/g...-25896408.html
Old Dec 26, 2023 | 6:59 PM
Extinct's Avatar
Thanks, that's a good price, would be better if it actually fit my connector.
Old Dec 26, 2023 | 7:03 PM
to me it looks like it matches the part you labeled "my sensors"
so post a picture of the pigtail because your post is very confusing. I don't know what's what.
Old Dec 27, 2023 | 4:55 PM
Extinct's Avatar
So I got the recommendation on several forums that the key is removable but could not seem to get the key to remove. I cut one of the junkyard sensors apart and I could see the seam line for the key insert so worked on it some more and I was able to get them to come out, then it plugged in to the truck no problem. So indeed, those keys are removable and likely stuck on my connectors. Now I just need a new sensor.
Ttrein
Jul 30, 2024 4:39 PM
blkfleet73
Dec 27, 2018 5:52 PM
Joe Piccirilli
2007 - 2013 (GMT900)
Nov 25, 2018 12:50 PM
osmonxp
Apr 28, 2018 5:06 AM
Satyr
20
Jan 1, 2015 7:12 AM
