1993 caprice leaks oil
found a 1993 caprice classic with 178000 miles i was thinking of buying the only thing is the guy says it has a oil leak and looses about a quart of oil a month if that.what would cause this and what should i look for when i go to look at it
update . it has the 5.0 v8 TBI in it what kind of oil leaking problems are they known for ? i have ben researching for about a week and know about the manifold gasket the rear main seal the oil switch and the distributor o-ring seal am i covering all the bases.the seller speaks very highly of the car and says it runs and drives great with only the oil leak issue
thank you
thank you
Well I own a 92 chev caprice, with a 305 in it, I have no serious leaks, just oil sweats all over the block. I have had a few drops come off of it, when I have it parked at an odd angle, and it was near the rear of the block. They're not really known for any serious leaks, just seals the sweat after age.
raweggfarts
Oct 21, 2014 7:55 AM
Mille Racer 69
12
Apr 12, 2011 9:04 AM
