ground issue
you measure the voltage drop after the load to the grounding point. power the circuit in question and put your meter lead after the load and the other on the grd point. should have less than 0.2volts reading on your meter.
but yes, post your concern. Hard to help when the problem is not known.
Is the car moving when this happens? Sounds like the speed sensor is at fault since those things are'nt adjustable, they just "fit" in. The other thing to add about grounds, Ohm meter with one side to battery ground, the other to "what area" you are wanting to check. There should be less than .3 ohms, that number will be bigger the further away you are from the battery, but not much.
One thing if you have an ohm meter, check both pins to ground, it should read either infinity, or a large resistance to ground, make sure the sensor is installed. Also check the sensor, that's both pins. You should have some resistance across the coil of the sensor, I don't know that value, guessing 25-200 ohms.
Last edited by kevinkpk; Sep 19, 2016 at 3:23 PM. Reason: Also check the sensor, that's both pins. You should have some resistance across the coil of the sensor, I don't know that val
