Interior lights and alarm going on after turning off the engine
Battery dead first thing in the morning. Husband jumps it off and went to work. Ten minutes after car was off the interior lights come on and alarm (horn) starts going off. After stopping it with key , it does it again a couple of hours later, by the end of the day battery dead again. Bought new battery, same problem. Each night we have disconnected battery until he can figure it out. Any suggestions please.
It just started the morning he had to jump start the battery. I did not lock my car doors at home and it would still go off. He unplugged the driver door actuator and it has stopped for now. Unsure if it is definitely that or BCM. He changed that door actuator within the last 6 months for another issue that was never solved. That issue was: the radio would stay on when engine is turned off and when the door opens it stays on. So I have to manually turn off the radio each time. Also not all of the doors lock and unlock properly with key fab.
Thank you, he found four broken wires where you said. He repaired them and it is working fine so far.
Thank you for telling us what your solution was. It may help someone else having a similar problem in the future. People often ask for help and get the problem fixed, but don't post back again to tell us what the solution was.
jpohl402
Apr 20, 2015 11:16 PM
