2015 Chevy Express Van 4500 parking brake light flashing while driving
Hello I have this 4500 express van that has a parking brake light that flashes for a bit and then goes away while driving the vehicle. We checked the brake fluid level, we checked for leaks, we checked the brake calipers and rotors but it all looks good. We checked and changed the sensor that goes on the brake master cylinder. The light goes off after about 10 min of driving but then goes away. Is it possible this is a cluster issue? Maybe an electrical issue or grounding issue?
Is it supposed to scan ABS systems? I didn't see it anywhere on this page: https://www.snapon.com/EN/US/Diagnos...ucts/APOLLO-D8
Yes it scans ABS systems and it has no codes at all no abs light or check engine light. What we have found now is that the light only comes on while it is stopped in drive and applying the brake pedal and when accelerating it comes off.
Maybe that light is hooked up to a pressure differential valve like old school pre-ABS systems and it catching a pressure differential? Maybe it's a fluid level sensor? Maybe it's the switch on the parking brake? I'd want to know if there is an internal leak in the master cylinder.
Stacey Conley
Jan 25, 2022 4:37 PM
jg33
Jan 3, 2021 3:17 PM
pickeral
Sep 14, 2007 9:47 AM
