abs system
Old May 20, 2007 | 4:51 PM
mog703's Avatar
Default abs system
2001 chevy impala, 85,000 miles. Brakes seem to work fine but almost daily at some point I can feel the ABS pulsating at any random time (not when the brakes are applied) It doesen't feel like the brakes are engaging just the slight pulsation for a second then the ABS light will come on and "usually" goes off within a few minutes. I want to send the car in for state insp. but some techs will not pass it if the light just happens to go on while he is working on the vehicle (located in PA) any ideas? Could this just be a normal reaction for the ABS system? Could I disconnect the light or pull the fuse for inspection then continue my troubleshooting? Inspection is scheduled for this sat. so ANY input would be greatly appreciated. Thanks
Old May 21, 2007 | 8:41 AM
golfer's Avatar
Default RE: abs system
If you remove the fuse to disable the ABS the light will come on and stay on.
Sirius018
Aug 23, 2010 12:24 PM
turboHD
Apr 21, 2010 9:29 AM
Shaun_95
Feb 12, 2010 8:38 PM
esrman
Mar 24, 2009 7:56 AM
1995Berretta
May 27, 2007 3:31 PM
