Notices
oil gallery plug
Old April 23rd, 2020, 1:32 PM
tonythecat1's Avatar
Default oil gallery plug
Hi all im new to the forum but hoping someone on here may be able to offer me some advise. i have a z20let engine and am fitting new oil gallery plugs. they are m14 tappered thread. the problem is i have made a boo boo and accidently used a straight tap to clear the threads my local engine shop says it will be fine if i use the correct thread seal. can you guys offer any advice
thanks
Old April 23rd, 2020, 2:46 PM
The oil system isn't under super high pressure. 60 psi max. So the seal doesn't need be incredibly precise. Worst case it'll just seep a bit over time. If you can live with that then do what the man says.
The alternative would be to use a M14 fastener that has a head. Then you could put something like plastic or copper washer under it to seal up tight (like your drain pan plug). The surface around the hole would have to be flat though.
Old April 23rd, 2020, 3:28 PM
Thanks very much for the reply. ok this reasures me a little. yeah i had considered the second option already but there is little surface ares to create a seal. im just looking and there is around 4 to 5mm of unthreaded section in the hole. im wondering weather it would be worth running the correct tap a little further into the hole to try and create a bit of tapper
Old April 23rd, 2020, 4:15 PM
kevinkpk's Avatar
You might be able to oversize it.
Old April 23rd, 2020, 4:21 PM
struggling to find a tapperd tap and plug bigger than 14mm
durdle
October 22nd, 2020 12:52 PM
drgnflys
November 26th, 2014 12:52 PM
pacaguy
September 3rd, 2012 12:44 PM
mulejr
January 20th, 2010 2:02 PM
admmck
November 19th, 2007 10:31 PM
Quick Reply: oil gallery plug
