oil gallery plug
Old Apr 23, 2020 | 1:32 PM
tonythecat1's Avatar
Default oil gallery plug
Hi all im new to the forum but hoping someone on here may be able to offer me some advise. i have a z20let engine and am fitting new oil gallery plugs. they are m14 tappered thread. the problem is i have made a boo boo and accidently used a straight tap to clear the threads my local engine shop says it will be fine if i use the correct thread seal. can you guys offer any advice
thanks
Old Apr 23, 2020 | 2:46 PM
The oil system isn't under super high pressure. 60 psi max. So the seal doesn't need be incredibly precise. Worst case it'll just seep a bit over time. If you can live with that then do what the man says.
The alternative would be to use a M14 fastener that has a head. Then you could put something like plastic or copper washer under it to seal up tight (like your drain pan plug). The surface around the hole would have to be flat though.
Old Apr 23, 2020 | 3:28 PM
Thanks very much for the reply. ok this reasures me a little. yeah i had considered the second option already but there is little surface ares to create a seal. im just looking and there is around 4 to 5mm of unthreaded section in the hole. im wondering weather it would be worth running the correct tap a little further into the hole to try and create a bit of tapper
Old Apr 23, 2020 | 4:15 PM
kevinkpk's Avatar
You might be able to oversize it.
Old Apr 23, 2020 | 4:21 PM
struggling to find a tapperd tap and plug bigger than 14mm
durdle
Oct 22, 2020 12:52 PM
drgnflys
Nov 26, 2014 12:52 PM
pacaguy
Sep 3, 2012 12:44 PM
mulejr
Jan 20, 2010 2:02 PM
admmck
Nov 19, 2007 10:31 PM
