Chevrolet Malibu
2007 LTZ - No heat when stopped
Old Sep 19, 2012 | 9:01 PM
schmaltzy's Avatar
Default 2007 LTZ - No heat when stopped
Wife turned the heat up today cause it's starting to get a little cold out. She said there wasn't any heat coming out so I hopped in and tested it out. Drove around for about 10 minutes there was zero heat. The car was at normal temp and outside temp was 60 degrees. Then, while driving down the road, it started blowing out heat but when I would come to a stop at a stoplight it would start blowing cold air again.
Suggestions?
Heating element (core?) might be bad?
Old Sep 25, 2012 | 7:59 AM
Official GM Rep
Suggestions?
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> schmaltzy,
I'm sorry you are experiencing this issue with your vehicle. If you would like, please PM me the last 8-digits of your VIN and I would be happy to check my resources for any known issues.
If you have any additional questions, please feel free to contact me.
I look forward to your reply.
Louis
GM Customer Service
Old Sep 25, 2012 | 8:46 AM
schmaltzy's Avatar
Thanks but you're too late. It was a leaking water pump. Already had it fixed.
Doug Suburban
Mar 23, 2013 9:05 AM
alaskan84
13
Feb 3, 2012 11:29 AM
RJK
Dec 20, 2010 7:05 PM
thehig
Uplander
Nov 26, 2009 9:11 PM
tumark
Apr 15, 2007 12:58 PM
