Chevrolet Malibu
Technical Service Bulletin
Old Dec 10, 2008 | 12:05 AM
exuL1B47's Avatar
Default Technical Service Bulletin
Hi
Does any body know of a website where you can search for a TSB by TSB #: were you can download or read the TSB for free? Thanks.
Old Dec 11, 2008 | 6:12 PM
shawnvw's Avatar
Banned
Default RE: Technical Service Bulletin
What are you looking for? Some of us can post them here for you if you'd like.
Old Dec 11, 2008 | 6:55 PM
exuL1B47's Avatar
The TSB I'm looking for is: bulletin 05-08-44-017
Old Dec 12, 2008 | 10:58 AM
gkiesel's Avatar
ORIGINAL: exuL1B47
Can you tell the rest of us what that bulletin concerns?
Old Dec 12, 2008 | 11:12 AM
exuL1B47's Avatar
2005 Malibu Maxx: AM radio static caused when rear window defroster is turned on.
Old Dec 13, 2008 | 7:38 AM
shawnvw's Avatar
Banned
This bulletin does not concern the mailbu maxx. It is only for the sedans. The sedans have the radio antenna built into the rear glass, while the maxx's have a standard antenna mast.
#05-08-44-017: Radio Static Noise on AM Stations when Using Rear Defogger (Install Capacitor) - (Jun 17, 2005) [/align]
[align=left] [align=left]
Subject:
Radio Static Noise on AM Stations When Using Rear Defogger (Install Capacitor)[/align][align=left]
Models:
2004-2006 Chevrolet Malibu (Sedans Only) [New Style][/align]
[hr]
Condition
Some customers may comment on radio static noise on AM stations. This static occurs when the rear defogger is on.
Cause
Power to the rear defogger generates the static.
Correction
Install capacitor (filter), P/N00477371, inline into the rear defogger circuit 293. This circuit is the power wire to the rear defogger. The color of the wire is purple and is located under the left rear corner upper garnish molding. Use the procedure listed below.
[ol]
Remove the garnish molding fastener cover.
Remove the garnish molding fastener.
Starting at the top, remove the garnish molding by pulling straight out.
Disconnect the rear defogger electrical connector.
Connect the male end of the capacitor to the rear defogger tab.
Connect the female end of the capacitor to the rear defogger lead.
Drill hole using drill bit.
Secure the capacitor to the body using a screw.
Starting at the bottom, install the garnish molding to the vehicle.
Install the garnish molding fastener.
Tighten
Tighten the fastener to 3 N·m(26lbin).
Install the garnish molding fastener cover. [/ol]
Parts Information
Part Number
Description
00477371
Capacitor[/align][/align]
Old Dec 13, 2008 | 12:01 PM
exuL1B47's Avatar
Hello Shawnvw
Good Job, thanks for the help. Have you herd or experienced this static problem before? The reason I ask is that I had the radio replaced once by GM and now I think I can take it back to the dealer and maybe have them install a part that can fix it. The radio plays great in all circumstances except when the static starts and it will actually stop if I turn on the rear window defogger. Thanks.
Old Dec 14, 2008 | 9:13 AM
shawnvw's Avatar
Banned
static goes AWAY when the defogger is on???
Usualy the static is present when the defogger is on. At any rate, It could be caused by a few things....the capacitor explained above, a defective\poorly grounded antenna module, or a break in the defogger grid. Do any of the grids not work when it is turned on?
Do you have a maxx or a sedan?
Old Dec 14, 2008 | 11:22 AM
exuL1B47's Avatar
Hi shawnvw
That is correct. After the radio was replaced (about 3-4 months ago) it started to go static again especially when I'm near high tension lines or metal bridges. I started trying every thing I could including: turning on the rear window defroster, and believe it or not, when I push in on the plastic reveal or molding that surrounds the perimeter of the radio, as long as I keep pressure it will stop the static until I release pressure. What really got me thinking about a capacitor was that now, when I just hold my open hand along side the frame of the radio it will, for a short time, stop the static. Now, since, the warranty is over, I don't know if the dealer will do anything. My Malibu is a (5) door Maxx. As I mentioned before the radio works great when the static stops; it has great tone and bass. I really like the Maxx a lot and the radio is all that has gone wrong; although, the mileage is very low; only approx. 5K. Thanks for all your help. PS: the only thing wrong with my fixes is that they don't last, like when I turn on the rear defogger, it will stop the static like zap but then about 4 minutes later its back.
Old Jun 6, 2014 | 8:42 AM
chevybig's Avatar
Default help for the maxx
I have a 2005 Malibu maxx the radio becomes static when I have the rear defrost on or im charging something in the outlet is there any simple fix? im kinda a diy guy
secorbust
Feb 25, 2013 3:41 PM
fijioehler
Nov 18, 2010 9:46 AM
stevetro1
Sep 8, 2010 3:10 PM
jricci
Mar 20, 2008 2:44 PM
lpmowles
Aug 8, 2007 6:33 PM
