1998 K1500 will not start
Old Nov 23, 2010 | 7:20 PM
CLSZ7198's Avatar
Default 1998 K1500 will not start
I have a 98 K1500 and it currently will not start. You roll the key forward and all you hear is a click from the starter. So I changed the starter and still all you hear is a click that happens once. So I decided to jump solenoid.. when I did the truck tried to crank..but all of a sudden the truck died. I currently have no power to my gauges and my truck will not click.. my lights still work but the gauges will not move and when you roll the key forward nothing happens. So have I blow a fuse somewhere trying to jump the solenoid?
Old Nov 26, 2010 | 6:50 PM
silverado13's Avatar
really sounds like a dead battery or bad ground
Old Nov 26, 2010 | 11:50 PM
2wd-K5's Avatar
either or, test the batt and clean the grounds up
Old Nov 27, 2010 | 3:44 AM
i mean try to jump start it and if it wont start then id assume its a bad ground
Old Nov 28, 2010 | 3:13 PM
CLSZ7198's Avatar
Yeah the battery is good checked that.. what grounds would you check I am not familiar with this?
Old Nov 28, 2010 | 5:37 PM
2wd-K5's Avatar
the one from the batt to the block and the one from the firewall to the engine block
also, did you try charging your battery?
Old Nov 28, 2010 | 10:23 PM
CLSZ7198's Avatar
Alright currently I have a brand new battery I got today and still the truck does not turn over. All the other lights in the truck come on other than the dash.. nothing happens when the key is rolled forward its as if you never rolled it over in the first place. Does this sound like the ignition switch?
Old Dec 4, 2010 | 12:39 AM
2wd-K5's Avatar
ok, sounds like the solenoid...even with a brand new starter, if your battery is weak or you have bad cables it can pop the solenoid they are cheap and better than replacing the whole starter again, but first check the fuses to make absolutely sure
Old Dec 4, 2010 | 1:01 AM
Mille Racer 69's Avatar
You definitely have a bad starter solenoid, I know the "click click click" sound from experience, it is a dead giveaway.
I think they are pretty inexpensive, just go buy 1. You may need to jump start the truck if the battery is dead.
For anybody that has not had a starter solenoid go out on them, it is a different type of
Clicking sound than a clicking sound that you would hear from say - a dead battery.
It is a distinct "click", similar to the click sound you may hear from the contactor
In your house thermostat when you switch on/off your heater or air conditioner.
Old Jun 24, 2013 | 6:44 AM
Jrocking's Avatar
New User
Awaiting E-mail Confirmation
There is two ignition Fuze under the hood one is 50 amp fuse and the other is a 60 amp fuse you might want to check that too if you havent allready did so jrocking@yahoo.com
Alston518
Jul 27, 2015 10:20 AM
RedondaBay
Jan 6, 2015 10:34 PM
unimog_jason
Oct 26, 2009 7:58 PM
jp.diddy
Nov 8, 2008 10:51 PM
