Code retrieval and wheel ??
Old Feb 25, 2013 | 1:39 PM
Misfit Toy's Avatar
Default Code retrieval and wheel ??
Just purchased a 2006 Z-71. PO told me the check engine light is on due to the 02 sensor, Is there a way to retrieve the code without a scanner. I thought there was a way on pre 99 but did not know if it was possible.
Also - will stock Chevy 16" wheels from an '03 fit / clear the rotors/brakes without issue or do i need to stick with the 17".
thanks for the replies.
Old Feb 25, 2013 | 3:03 PM
kevinkpk's Avatar
Pre 96 was OBD1, and yes without a scanner. Most parts stores will read the code for you.
Old Feb 25, 2013 | 3:54 PM
Misfit Toy's Avatar
thanks kevinpk, thanks for the correction of years,
i realize that the auto parts will read it for me. that was not the question. is your answer no the code can not be read without a scanner?
thanks
Old Feb 25, 2013 | 4:44 PM
kevinkpk's Avatar
thanks
I don't know on an OBD2.
Old Feb 25, 2013 | 8:09 PM
you need a scan tool.
Old Feb 26, 2013 | 7:02 AM
Misfit Toy's Avatar
Ok thanks,
Didnt even think to look at Specs on NADA 16" was standard.
Old Feb 26, 2013 | 7:33 PM
country_09's Avatar
Do you have drum brakes in the rear? If you do, 16s won't clear the front caliper unless you grind them down. And yes you need a tool
Old Feb 27, 2013 | 7:06 AM
Misfit Toy's Avatar
thanks tech, kevin, country
NADA specs says 16" was standard on this truck. just wanted to find a deal on some. 16"s should work
Old Feb 27, 2013 | 2:06 PM
country_09's Avatar
May be true, but in 05-07 silverados came with 13" rotors up front and drums out back. With these rotors you could only run a 17 or bigger. 16s will work with some grindin on the caliper
Old Feb 27, 2013 | 4:51 PM
Misfit Toy's Avatar
i hear ya, little confusing when the spec sheet say s 16" wheels. will see what i have for sure before i buy.
appreciate all yalls help
Billy HC
Dec 10, 2018 1:59 AM
J C Smith
Jun 21, 2014 9:29 PM
Donthaveone
Aug 27, 2013 9:45 PM
Vinna
Nov 12, 2012 8:51 AM
rap1
Oct 26, 2008 12:44 AM
