Old Jul 24, 2015, 6:15 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community expertsBrowse all: Engine and Powertrain
Print Wikipost
flex fuel engine
Old May 5, 2012 | 10:42 AM
dryzn1's Avatar
Default flex fuel engine
hi
my silverado 2008 5.3 flex fuel engine. i want to know the location of the fuel filter?
and cabin AIR filter ?
and the time i should change them
when i use my A/C always switch 1+3 button,,, but when i want to use my in cabin cold air i switch off 3 ... i noticed that the A/C compressor still work ... is it normal ? how can i use cabin air with out use compressor ?
thanx
Attached Thumbnails flex fuel engine-2011-chevrolet-silverado-1500-hybrid-4wd-crew-cab-143-5-2hy-temperature-controls_100337874_l.jpg
Old May 5, 2012 | 3:16 PM
cleveland63b's Avatar
there is no cabin air filter and I dont think the fuel filter is serviceable would have to look it up
Old May 6, 2012 | 2:11 PM
dryzn1's Avatar
Default there is no cabin air filter
sure --- how this go ???!!!
Old May 6, 2012 | 9:42 PM
Doug Roberts's Avatar
Yeah there is lol its under glove box I think every car/truck has it
Flex filter is / should be under driver door inline with fuel filter should throw a code when it needs it and my old flex fuel only turned on filter when I used e85
Old May 6, 2012 | 10:21 PM
MDTAHOE's Avatar
Professional Mechanic
As cleveland63 stated there is no cabin filter. The fuel filter is not serviceable as it is part of the fuel pump. Despite what was posted above there are lots of vehicles without cabin filters. The serviceable fuel filter has become a thing of the past on most makes and models.
Old May 6, 2012 | 10:22 PM
EinST's Avatar
As for the A/C compressor behavior, it'll run when the HVAC controls are in the recirc, defog, or defrost mode unless it's freezing outside.
Old May 7, 2012 | 10:02 PM
chevy pickups,tahoes,suburbans all stopped coming factory with cabin filters in 02 and suvs/passenger cars are hit and miss and although i disagree with it not many flex fuel vehicles have serviceable fuel filters
Old May 12, 2012 | 11:36 AM
dryzn1's Avatar
thanks guys...but if there is not A/C cabin filter what should i do to decrease bad air from out side any ideas???
Old May 12, 2012 | 12:04 PM
EinST's Avatar
I mostly use the recirc mode to keep the dust and exhaust fumes out.
ronboc
Jan 8, 2023 11:13 PM
adamanddiane
May 27, 2022 3:10 AM
bholaday
Apr 2, 2021 5:51 PM
Typerod
May 6, 2007 11:09 PM
MikeNAmyS
May 2, 2006 2:23 PM
