No 4wd in Reverse?
Old Jan 29, 2014 | 5:16 PM
classicindy650's Avatar
Default No 4wd in Reverse?
I have a 1999 Silverado 1500 4wd. I can not figure out why I have no 4wd in reverse, it works good in drive, but only rear tires spin in reverse. No weird noises, reverse works when not in 4wd. Any ideas? Thanks
Old Jan 30, 2014 | 8:45 PM
any ideas? thanks
Old Jan 31, 2014 | 3:50 AM
Allan In NE's Avatar
Assuming you have the electric shift? Do your backup lights work? Are you getting the "Service 4X4" message on the instrument cluster?
Allan
Old Jan 31, 2014 | 9:22 PM
no service 4wd light on and all back up lights work. is there a reverse gear in the transfer case? I was told that gear was bad?
Old Feb 1, 2014 | 8:50 AM
No, there's no reverse in the transfer case. It is a simple in/out box.
Humor me, go put the truck in Lo 4X4 and see if your four wheel drive comes back in reverse.
Allan
Old Feb 1, 2014 | 4:01 PM
I had truck in 4lo when I got stuck in a very small dip in my drive way, kind of the edge of the drive way. I have been using auto mode and seems to work, I really don't want to attempt trying to get stuck to really tell, but seems good on level ground.
Old Mar 27, 2021 | 11:48 AM
Corey Mcmurry's Avatar
Default Did you ever figure it out
I have a 2000 chevy 4x4 blazer that my 4wd isn't working in reverse. Works great going forward
Old Mar 27, 2021 | 9:48 PM
what tcase do you have?
Old Mar 29, 2021 | 6:32 AM
Default No 4wd @ all
I'm not sure what tcase. I have a 5spd manual Trans with 3 probe l buttons on dash for the 4wd. I only thought I had 4wd going forward cause I could hear the tcase switch and my gear ratio will change to 4lo. But the front tires don't spin when I'm stuck
Corey Mcmurry
Mar 28, 2021 9:37 AM
Mr-Magoo
Dec 19, 2014 4:46 PM
JapanAaron
16
Mar 15, 2014 3:50 PM
DanielW4444
Mar 24, 2009 5:47 PM
DianaT
Nov 29, 2007 12:12 AM
