wont start
Old Jul 1, 2012 | 2:46 PM
kane1234's Avatar
Default wont start
Hello .Im in need of some help .I have a 1994 chevy 1500 with the 5.7 tbi motor.I died the other day and would not start .Had to pay for the tow home .I could hear no fuel pump rumming so I replaced it and the filter.No go .I have fuel at the tbi .I can dump fuel down the tbi and it starts up and runs fine.Turn it off and no start unless i reprime it .Any help would be great .i cant afford to take it in or any expensive tools .Thanks
Old Jul 1, 2012 | 2:53 PM
kevinkpk's Avatar
Does it stay running after you prime it?
Old Jul 1, 2012 | 2:54 PM
kane1234's Avatar
yes it does .No stumble or rough running .I can revit it up and let it return to idle.It is driving me nuts .I need th truck to get to work.Thanks
Old Jul 1, 2012 | 3:28 PM
kevinkpk's Avatar
Two things, what is the idle rpm? I think there is a check valve that prevents total fuel drain back, thats where I'd look. Not trying to sell a Haynes or Chiltons, but I don't know where to tell you to look. Check valves rarely go bad, but you could have trash in it keeping it open on shutdown.
Old Jul 1, 2012 | 3:32 PM
kevinkpk's Avatar
I don't have anything on this model, I am sure there is a check valve in the system, it might even be in the fuel filter. I hope someone else can respond. Brother I know what it's like to have to get a vehicle running when broke on the weekend to get to work.
Old Jul 1, 2012 | 3:54 PM
kane1234's Avatar
Hello.The truck is idling perfect after I prime it .I just can understand how it can run and idle perfect after.I prime it.It has to have spark and fuel to run but it just wont do it without a prime.Where is the check valve located .Any other ideas would be great .i need to get to work .Cant afford to loose the job.Thanks
Old Jul 1, 2012 | 3:56 PM
kevinkpk's Avatar
It may be in the filter. Follow the fuel line under the frame (I am not sure where it is, but sure it has one).
Old Jul 1, 2012 | 4:07 PM
kane1234's Avatar
Thanks .I replaced the filter along with the pump .Is the check valve seperate from the filter.Thanks
Old Jul 1, 2012 | 4:34 PM
kevinkpk's Avatar
I don't know, probably not since you replaced the filter. Get a fuel system diagram, and see if (I am sure it does) where it is.
Tootallmech
Aug 7, 2023 11:49 AM
sleepingciv
Jul 25, 2020 1:03 PM
bracca
Jul 12, 2009 6:14 PM
wildboy74ss
Apr 1, 2009 5:10 PM
