Sonic (Aveo) The subcompact known globally as the Aveo since 2002 is now the SONIC in North America as of the 2012 model
Chevrolet Sonic
GM Platform: T200, T250, T300
a/c not working in 07 aveo
Old Jun 9, 2013 | 1:16 AM
miss24fan's Avatar
Default a/c not working in 07 aveo
My 07 Aveo LS a/c doesn't blow cold. Had the dye test done and no leak, did the empty and recharge done and no cold air still. Was suggested to to the expansion valve and see if that works. anybody else have this same issue? if so..any advice?
Old Jun 25, 2013 | 8:30 PM
go-part's Avatar
Former Sponsor
5 Ways to Diagnose a Non Working Air Conditioning in a Car
Air Conditioning Troubleshooting and Repair
Old Aug 28, 2013 | 11:38 PM
andyabott's Avatar
2007 Model has an issue with his AC system and you should to check is there any leakage of Feron from the compressor.You should go to mechanic to fix the problem.
Old Oct 9, 2013 | 8:30 PM
Steve1's Avatar
I would recommend an ac specialist here as well. I've worked on ac for 30 years. High pressures and high heat on return lines make this dangerous for the novice
Scoobysam
Mar 29, 2015 9:30 AM
itzkatiejo
Sonic (Aveo)
Mar 7, 2015 11:43 AM
ab0z
Sonic (Aveo)
Aug 8, 2012 9:54 AM
darcyb71
Sonic (Aveo)
May 5, 2012 1:18 PM
ezzyboy954
Feb 9, 2011 12:12 PM
