2008 Tahoe Electrical Problems
Old Mar 24, 2016 | 8:44 AM
  #31
Thanks Davidsweet ! Your follow up on the fix and how you troubleshot the problem(s) could be a real time saver for some else This is what makes a forum work!
Old Aug 1, 2016 | 7:58 AM
  #32
Luca Brasi104's Avatar
Default Second battery
How did you connect the second battery? I've been trying to find out how to do it but no luck.... If you could please help me that would be awesome
Old Aug 1, 2016 | 9:52 AM
  #33
Luca Brasi104
Welcome to the forum..
There are a couple of ways to connect a second battery and it will also depend on how you want that battery utilized, you can use the forum search feature , here is one of the write ups
https://chevroletforum.com/forum/tah...upgrade-65109/
Old May 15, 2017 | 10:12 AM
  #34
Wes Moore's Avatar
I recently bought a 2008 Tahoe and it has just started with these same problems, they seem to get worse every day. I find it ridiculous that this problem is so common and Chevrolet has not recalled it! It's readily apparent that this a design flaw by Chevrolet and it's abhorrent that they will not stand behind their mistake. I am a die hard Chevy fan and have owned exclusively Chevrolets my whole life, you expect us to be loyal to your brand and stay that way then you need to step up when it becomes overwhelmingly clear that this is not just normal wear and tear but rather a bad design and fix it! The answer should NOT be, "take it to your local dealership and pay close to a grand to fix a problem that shouldn't have happened in the first place. You have designed cables with faulty connectors which cost over 100$ a piece and there isn't just one simple positive and ground but multiple cables all of which are outrageously priced, faulty junction boxes, and faulty fuse relay connectors. It's not simple corrosion when you have nearly a decade long thread with the exact same complaints. Smh shame on you Chevrolet.
Tondojr9
Sep 11, 2020 12:48 AM
G P Meyers
Uplander
77
Apr 15, 2020 2:37 PM
engine73driver
Mar 2, 2014 2:16 PM
BZ Man
Aug 24, 2011 6:57 AM
silberm3
Jun 30, 2011 7:32 AM
