99 Suburban Won't Start
Old Jun 16, 2020 | 5:15 PM
burbbarbie's Avatar
Default 99 Suburban Won't Start
UPDATE: It was my fuel pump. Truck is running now.
The truck gets fuel and you can hear the fuel pump come on and go off. If you bleed the fuel line, gas comes out but it's like a trickle. The dash lights that are on are Check Gauges, Service Engine, and the battery icon. I get the following code
P0304.
Any ideas before I have to start buying a bunch of parts that don't help fix the issue?
P0304
Old Jun 16, 2020 | 5:17 PM
Rednucleus's Avatar
I wouldn't think one cylinder would cause a "no start" condition; might run crappy but should still start. Does it try and run or just turn over w/o firing at all?
Old Jun 16, 2020 | 5:24 PM
burbbarbie's Avatar
It turns over. The guy poured gas in the mod (carburetor looking thing) and it starts for a few seconds then cuts off. I've had 3 people look at it and they are saying fuel pump needs replacing but they all said they can hear it come on and go off.
Old Jun 16, 2020 | 5:43 PM
kevinkpk's Avatar
Same here. If you are getting a trickle from the fuel rail, I'd look at fuel pump.
Old Jun 16, 2020 | 9:35 PM
Rednucleus's Avatar
If it starts/runs pouring gas in, you know you have spark. In my 93 when it did this I replaced the ICM in the distributor and that fixed it. It has happened to me twice.
Old Jun 16, 2020 | 11:51 PM
burbbarbie's Avatar
ICM is ignition control module?
Old Jun 17, 2020 | 10:02 AM
Rednucleus's Avatar
Correct - for my 93 the failed icm shut down the throttle body injectors. Pump ran but no injector operation. Don't know if a 99 has same unit in distributor but it's an easy part to change, not overly expensive and commonly fails.
Old Jun 20, 2020 | 8:12 AM
repairman54's Avatar
Change the fuel filter is step one for low flow.
sub29
Feb 1, 2013 6:21 AM
bigk101
Jan 1, 2013 3:30 PM
Superman13
Apr 9, 2012 11:40 AM
smd900
Astro
Apr 2, 2011 9:57 AM
rjellis
Aug 9, 2009 10:08 PM
