99 TAHOE / heater is not hot anymore. won't get hot.
Old Feb 17, 2009 | 8:20 PM
TahoeMatt's Avatar
Lightbulb 99 TAHOE / heater is not hot anymore. won't get hot.
I love my 99 Tahoe. ( just wanted to get that out there )
My Tahoe's heater isn't getting hot anymore. It seems to get a little hot but it's not consistent. There where no wierd smells coming from it. ( I do know that in the summer time several months ago when trying to charge the ac pump it was making a wierd noise when the ac would get turned on / not sure if that's relevant at all. ) .
Any input is greatly appreciated.
Thnx. Matt
Old Feb 17, 2009 | 9:50 PM
MDTAHOE's Avatar
Professional Mechanic
If your coolant is full, most likely you need a t-stat
Old Feb 18, 2009 | 12:47 AM
TahoeMatt's Avatar
Thumbs up thnx
thanx for the input. i will check it out. hope that's it.
Old Feb 18, 2009 | 9:27 AM
Welcome to the forum
Its possible the heater core could be plugged up, flushing it may help.
If green anti freeze has ever been mixed in with the pink stuff it will create a cheese mix perfect for clogging up a heater core.
Old Feb 18, 2009 | 8:39 PM
TahoeMatt's Avatar
Thumbs up thanks again
the input is appreciated !!!
Old Feb 19, 2009 | 12:43 AM
Tommy's Avatar
also you could simply have air in the coolant system and could just need to be burped is all i could think of every thing else was stated
Old Oct 15, 2014 | 9:05 AM
humheadfish's Avatar
Smile 99 Tahoe No heat
I have a 99 Tahoe that I absolutely love! Best vehicle I've ever owned!
The challenge I'm having with her is she has no heat. I had the thermostat replaced yesterday. Still no heat.
Any help would be appreciated!
Old Oct 15, 2014 | 4:10 PM
Welcome to the forum.
First check for water control valves in the heater hose lines. If it has any, check to make sure that they are opening properly.
Does the engine temperature go up to the normal operating temperature? Does it have rear heat? If it does, does it work?
atex33
Feb 10, 2013 12:18 AM
MAD King
Apr 7, 2010 11:11 AM
pjustus805
Jan 5, 2009 12:55 PM
dalsx1
Jan 2, 2009 5:04 PM
