Broken off rear window defroster connection
Old Aug 2, 2016 | 7:00 PM
Typerod's Avatar
15 Year Member
Default Broken off rear window defroster connection
I tell ya when it rains it pours man! I just replaced the front calipers and flex brake lines on my 07 Tahoe, and now this evening I start packing up my Tahoe for a visit to see my folks, and I see that driver's side connection for the rear defroster is completely broken off from the glass. My wife and kids just returned from a few days in PA, and I know one of them did this, but no one is confessing. Can this be repaired? Or is the only fix replacing the rear glass? AAAAAAAAAAAHHHHHHHHHHHHHHHHHHHH!!!!!!!!!!!!!!!
Attached Thumbnails Broken off rear window defroster connection-img_1235.jpg   Broken off rear window defroster connection-img_1233.jpg
Old Aug 2, 2016 | 8:25 PM
cleveland63b's Avatar
it can be soldered back on, its not much fun and you need to use silver solder but it is possible.
Old Aug 2, 2016 | 9:36 PM
First thing to do is to check to make sure that the one that is still attached is slack when the window is shut. If it's not slack, stretch it until it is. Some on the forum have successfully used the kit that is used to repair broken defroster lines which is basically a conductive epoxy to reattach the terminal to the window.
Of course you will want to stretch this one also before reattaching.
Old Aug 2, 2016 | 11:03 PM
intheburbs's Avatar
You can try this stuff - specifically designed for the task. Click HERE
In all honesty, I tried the repair three times with this stuff - couldn't get it to work. Tabs kept coming off. But I think the previous owner really hacked it up, too. Besides, my windows are so deeply tinted back there, it really doesn't make much of a difference, and I've got the oversized towing mirrors that are heated, so I'm pretty much GTG even with no rear defroster.
Old Aug 3, 2016 | 10:00 AM
Typerod's Avatar
15 Year Member
Thanks all! My back window is limo tinted. But it still irks me to just leave it broken like that, lol. I take that I need to scrape the white coating on the "conductor tab" before I try any of the suggested fixes, right? It seems that white coating would be conductive too, but I dont know all about this issue.
Old Aug 3, 2016 | 8:09 PM
there was a service bulletin for a certain range of vehicles that I think had instructions on how they recommended you solder it back on, I'll try to look later if I remember
Old Aug 3, 2016 | 9:18 PM
If you elect to use the epoxy or solder, the terminal and glass should both be scrupulously clean.
Old Aug 4, 2016 | 8:16 AM
#03-08-48-006J is the bulletin, not sure if you can find it on google or anything. On a side note if you do go this route keep in mind under warranty it only pays a guy .3 (18min) to do the entire job....oh the joys of working for a dealer.
Old Aug 5, 2016 | 8:01 PM
Typerod's Avatar
15 Year Member
Thank you shark and cleveland for your help! The bulletin number is especially helpful, to understand the repair, thanks again! I can always count on the members here!
Old Aug 6, 2016 | 2:28 PM
There are a couple of threads on this topic
https://chevroletforum.com/forum/tah...007-sub-63126/
https://chevroletforum.com/forum/tah...efogger-57659/
https://chevroletforum.com/forum/tah...ell-off-39447/
