IR Receiver
Old Mar 12, 2018 | 5:59 PM
Mmenzies@aol.com's Avatar
Default IR Receiver
can anyone tell me where the fuse is for the IR Receiver
1. Key fobs don’t work and won’t reprogram. I bought two new fobs and they won’t program either
2. Service tire monitor warning is on
both happened at the same time
I am assuming that the IR receiver has gone bad but before replacing would like to check the fuse if I can find where it is
Many thanks in advance
Mark
Old Mar 14, 2018 | 8:45 PM
Any takers here. Any help would be much appreciated
thanks Mark
Old Mar 15, 2018 | 6:59 AM
SabrToothSqrl's Avatar
Well.... there are no IR Receivers on a Tahoe. Everything you mention is RF...
I also wouldn't be sure they were related. Usually the receiver for the fobs is not the same device or frequency as TPMS. TPMS only needs a rather short range, while the Fobs need a longer range.
If I knew where the receiver was I'd tell you, but I don't. Sorry.
Old Mar 16, 2018 | 5:22 AM
a55bruce's Avatar
Knowing what model and year would help.
Old Mar 16, 2018 | 8:25 AM
depends on the model and build
some models use the remote control door lock receiver or rcdlr for keyless and tpm functions. Some use the tailgate module for tpm functions.
it would be a leap to say the module has gone bad at this point...without pulling codes or any diagnostics.
Old Apr 7, 2018 | 7:16 PM
2004 suburban LT. can not reconnect TPMS or remote key fobs when I try to reprogram
Mark
Old Apr 9, 2018 | 10:56 AM
a55bruce's Avatar
The Remote Control Door Lock Receiver (RCDLR) for the key fob is powered by the DSM fuse located in the instrument panel fuse block.
<Edit> Ignore this really bad advice!!! I was looking at the wrong schematic <Edit>
Last edited by a55bruce; Apr 11, 2018 at 8:15 AM. Reason: Stupid mistake on my part (sometimers disease)
Old Apr 10, 2018 | 2:42 PM
QA
Can’t find the DSM fuse in the instrument pane” fuse box
trying to post a pic
Old Apr 11, 2018 | 9:04 AM
a55bruce's Avatar
Originally Posted by Mmenzies@aol.com
QA
Sorry for the bad advice, I was looking at the wrong schematic.
Are you following this procedure for programming the TPMS?
1. Apply parking brake. Turn ignition to ON position (engine off)
2. Turn headlight switch from “Off” to “On” four times within 3 seconds. A double horn chirp will sound and the TPM low tire warning light will begin to flash.
3. Starting at the LF tire increase/decrease pressure until horn sounds.
4. After horn sounds, proceed as in step 3 for the next 3 sensors in the following order : RF, RR LR.
5. After LR sensor has been learned, turn ignition to OFF position.
Old Apr 11, 2018 | 11:21 AM
yes to the TPMS programming procedures and following the correct procedure for the keyless entry procedure with no response. Have to believe the two issues are connected.
Either faulty receiver or blown fuse. Wanted to check the fuse first before proceeding to the receiver
Mark
