Misfire after replacing everything?
Old Jun 28, 2021 | 5:46 AM
WiseMountainApe's Avatar
Default Misfire after replacing everything?
I've got a 2004 Suburban 1500 5.3 Vortec V8 flex fuel. It started giving me a misfire code on #2 cylinder. I've replaced the spark plug, plug wire, ignition coil, and fuel injector, but still get a fouled plug with oil on it. I put a spark tester on it and could see a orange color spark so I see spark. I did a compression test and got 175 psi on #2, and 180 on #4 cylinder so that is encouraging. I am still getting that misfire with oil on the fouled plug. I've swapped ignition coils from #4 to #2 with no better effect. I"m not sure where to go from here.
Any help would be great.
Old Jun 28, 2021 | 7:07 AM
hanky's Avatar
It does sound like there may be a problem with a cracked oil control ring on that cyl piston.
How long does it run fine before the plug gets loaded with oil?
Old Jun 28, 2021 | 8:53 AM
The misfire comes back pretty much immediately. Would a leak down test help identify that condition even though I had solid compression in the cylinder?
Old Jun 28, 2021 | 9:08 AM
do you get blue smoke out the tailpipe on start up or on hard acceleration?
Old Jun 28, 2021 | 9:12 AM
More of a faint white smoke. Oil on the dipstick is dark ( no milkshake). You rev the engine you get more smoke, but not alot really.
Old Jun 28, 2021 | 11:28 AM
valve stem seals can leak and leave a build up of ash deposit on the center electrode of the spark plug. you will also get a puff of smoke on start up. Will not effect compression readings
post a pic of the plug
does it stop misfiring for a bit after plug replacement?
Old Jul 5, 2021 | 2:54 PM
Thanks for the reply. I did a leak down test on that cylinder and it seemed pretty solid. I cranked it up to about 100 psi and could hear air from the oil tube, but not the exhaust pipe, throttle body or radiator, so I guess you may be right about the oil ring. It seems strange that I have good compression, but oil is getting by the compression rings. Where am I wrong about that? Thanks!
Old Jul 5, 2021 | 7:24 PM
what is the percentage of leakdown?has to be over a certain % to fail.
Old Jul 5, 2021 | 8:27 PM
Less than 10%. No noise from exhaust, throttle body, or bubbles in coolant. Only a faint hissing noise coming from the oil tube when I turned the psi to around 100.
Old Jul 13, 2021 | 9:41 AM
Thanks for you input. It turns out I had a broken rocker arm on that cylinder. Now that I have that fixed we'll see what other codes this truck has to throw me.
Timothy.Johnson
Feb 8, 2021 5:11 PM
p0zburn
Dec 2, 2013 8:08 PM
unkindshadow35
Feb 2, 2013 10:50 PM
cyras21
Oct 8, 2011 2:39 PM
