No Domelights and sunroof inop...
Old Sep 24, 2015 | 7:36 PM
PackersFan's Avatar
Default No Domelights and sunroof inop...
Hi I just bought this 2002 Tahoe with 89k miles on it. However the Dome lights and sunroof don't work. The fuse under the hood pops instantly. I have pulled out all bulbs and unhooked sunroof motor, and fuse still blows instantly. I pull inadvert relay and fuse doesn't blow and if I unplug Brown connector on BCM it doesn't blow with Inadvert relay in. Swapped relays around and no change. So where would I begin looking for dead short to ground on an orange wire? I'm a professional mechanic and im totally stumped on this.
Old Sep 26, 2015 | 8:05 AM
a55bruce's Avatar
Originally Posted by PackersFan
... I pull inadvert relay and fuse doesn't blow ... So where would I begin looking for dead short to ground on an orange wire?
Are you referring to the orange wire from the INADV relay? If yes, that wire feeds the Courtesy Lamp Module. You may have a bad module, or a short on the ORN/BLK wire feeding the interior lights from the module.
Steelers Fan
yukon_ray
May 21, 2015 8:32 PM
1Ton-K1500
Sep 29, 2014 11:02 PM
Mike@VengeancePCM
Feb 22, 2011 7:47 PM
d1nonly34
Jun 15, 2009 10:38 AM
e
Jan 20, 2008 12:06 PM
