Rear LED tails on hybrids
Old Jan 21, 2009 | 11:13 PM
Tahoe fan's Avatar
Default Rear LED tails on hybrids
Can they be installed on a regular Tahoe?
Old Jan 22, 2009 | 5:16 PM
Willys 53's Avatar
I was wondering the exact same thing? Although, it looks like only the top half of the assembly contains LED's, correct?
Old Jan 22, 2009 | 8:28 PM
Tahoe fan's Avatar
No, the top and bottom are LED and the center back up is a bulb. I was wondering if the connections to the housing and Tahoe's harness mate. If they do then it is a plug and play.
Old Jan 22, 2009 | 10:11 PM
MDTAHOE's Avatar
Professional Mechanic
You could go to a dealer that will let you take one for a test drive by yourself. Pull over remove the tail light and take a look.
Old Jan 23, 2009 | 5:18 PM
Unless you are really sold on them, there are other options that are probably cheaper. For instance, Eagle Eyes are ~$250 at Custom Creations.
Old Jan 23, 2009 | 11:00 PM
Tahoe fan's Avatar
Do you have any pictures? Please post.
Old Jan 23, 2009 | 11:28 PM
EvansBlue's Avatar
I would imagine that the same harness is in the Hybrid and Non-Hybrid models. Usually lighting harnesses do not change between build packages...
I could be wrong though, just thought I'd inject my idea.
Old Jan 27, 2009 | 2:30 PM
Here's some shots. Daytime, on, brakes, & on w/ backups.
Old Jan 27, 2009 | 4:52 PM
EvansBlue's Avatar
Wow Marc. They look good. Kinda reminiscent of the 88-99 C/K sereis models with the location and shape of the b/u light.
cpk
Jun 7, 2010 9:33 AM
Fast55
Sep 29, 2009 1:45 PM
in2pro
Nov 20, 2008 3:16 PM
biglg
Jan 27, 2008 9:42 PM
jazejeff
Jan 9, 2008 7:25 PM
